Lost my second display
Just updated (Shipped Manjaro, Firefox, etc.) and now my second display is not seen in display configuration and does not work anymore. It was working and had been for months. Set up is through the pbp docking station. Was working with HDMI (except no sound), now does not work through HDMI or serial cable. Anyone know how i can get this working again? Display configuration settings are totally greyed out as if there is only a laptop screen.
Like i said this was working literally 15 minutes ago before i did the update (that came out on 5/31/2022 i believe).
I have rebooted and plugged and unplugged and any simple things i could think of.
Thanks in advance for any ideas-
I don't currently use manjaro at the moment but I did in the past, here's what I think happened.
Manjaro uses a patched kernel for the pinebook pro in order to get DP over USB C working, this is the protocol which allows for the dock to work (even if the dock has hdmi instead of display port).
This means that the new kernel is probably missing the patch.
You can try looking in you package cache for pacman if you still have the old kernel laying around
(the cache should be at /var/cache/pacman if memory serves me right).
You should also look at which kernel you have installed exactly.
Run
pacman -Qq | grep linux
If you see something like linux-pinebookpro, then you are using the pinebook pro specific kernel (this may also be called linux-pbp or similar).
If the installed package is just "linux" (followed by a version) then try looking for a pinebook pro specific kernel in the manjaro repository.
Hope that helps,
User
I am running the stock linux that came with the device.
Here is the output of the command:
archlinux-appstream-data
archlinux-keyring
archlinuxarm-keyring
linux
linux-api-headers
linux-firmware
linux-firmware-whence
util-linux
util-linux-libs
I expect you are right, i must be mising the patch to make it work now.
(06-04-2022, 09:20 AM)WEF Wrote: I am running the stock linux that came with the device.
linux
Right so that is "upstream" linux package. The "linux-pinebookpro" package is avaible in manjaro's core repo but it is an older version.
I believe the main manjaro linux kernel (the one you have) SHOULD work with your external display.
Check the pacman cache for an older version.
Otherwise, this repo: https://pacman.kiljan.org/archlinuxarm-pbp/os/aarch64/ Contains linux-manjaro-5.18.1-3 which should work with e-DP1.
linux
Otherwise, this repo: https://pacman.kiljan.org/archlinuxarm-pbp/os/aarch64/zameenContains linux-manjaro-5.18.1-3 which should work with e-DP1.
Yes I also used the same repo you mentioned and it has worked for me, I hope it will also work for him too. I was also searching for it and then found it in some other forum here.
still no fix?...have to roll linux-manjaro kernel back to the 5.17 update i did on Kiljan's arch when using external hdmi.
does the manjaro team care about getting it patched ... are aware of it?
btw i use the downgrade/aur script to go back and for ,when needed,works like a charm.
  PinebookPro Display Corrupts/Cuts Out Twig 5 2,244 06-11-2023, 07:59 AM
  PBP green LED works but blank display. frerebo 1 877 02-22-2023, 03:11 AM
  Issues with External Display After Recent Update reundo 0 1,379 11-18-2021, 06:37 PM
Last Post: reundo
  No Display on PBP PitCritter 2 2,285 09-04-2021, 12:05 AM
Last Post: lot378
  Pinebook Pro - Display cable broken? snokis 0 1,520 08-17-2021, 11:30 AM
Last Post: snokis
  pinebook pro dock display out mamboman777 0 1,514 07-29-2021, 10:41 AM
Last Post: mamboman777
  USB C dock with internal display mirrored to projector and one extended display jbrock 4 3,083 07-19-2021, 04:00 PM
Last Post: jbrock
  [split] U-Boot with NVMe support, keyboard & display working as400 83 82,739 01-27-2021, 12:48 AM
Last Post: as400
  No keyboard & trackpad leads to no display. RMA from the US. Free parts in Seattle BitterPine 4 8,554 12-30-2020, 06:14 AM
Last Post: BetteHoward
Exclamation Seemingly lost power permanently now /cry jimsurvak 2 3,090 11-16-2020, 06:22 PM
Last Post: jimsurvak
