PinebookPro Display Corrupts/Cuts Out
Got a screen issues, that comes up in different ways.
Before my Pinebook Pro boots the OS, if I tilt the screen I sometimes get a bunch of garbled characters on the screen and the screen goes black (but still on).
Other times it'll boot normally and if I so much as touch the laptop it'll cut out.
Yet sometimes (and this strange), it'll boot normally, I can tilt the screen, move the laptop etc and nothing will go wrong.
Any ideas where to begin here? Some loose connector?
Thanks,
Twig
I've opened it up and made sure every appears to be connected, no change.
Would a replacement screen solve it?
Latest attempt, the screen went black after logging in, followed by a hissing noise!
It sounds like a bad connection or cold solder joint related to the backlight.
:wq
[ SRA accepts you ]
(12-11-2022, 08:10 AM)KC9UDX Wrote: It sounds like a bad connection or cold solder joint related to the backlight.
Ah right, thanks for the info.
Bit beyond my abilities to fix!
Cheers
The worst part is it may be a broken wire too, and isolating the problem will be a crapshoot.
If you had a second, working PBP, you could swap parts to isolate the problem. Else you'll end up buying a lot of parts before you can find it. How old is the PBP? You might be able to warranty exchange it. Otherwise, if you can afford it, you could buy another one and swap para to find the problem and then buy replacement parts and sell the working one (or keep it! If you're like me you can always find uses for another one).
:wq
[ SRA accepts you ]
  PBP green LED works but blank display. frerebo 1 874 02-22-2023, 03:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,756 01-22-2023, 10:05 PM
Last Post: rfm83
  PinebookPro CPU Speed setting therosery 0 676 09-07-2022, 05:02 AM
Last Post: therosery
  Lost my second display WEF 5 2,998 08-18-2022, 07:53 AM
Last Post: josmo
  PinebookPro Build Errors mexsudo 3 2,914 01-30-2022, 08:36 AM
Last Post: mexsudo
  Issues with External Display After Recent Update reundo 0 1,372 11-18-2021, 06:37 PM
Last Post: reundo
  No Display on PBP PitCritter 2 2,275 09-04-2021, 12:05 AM
Last Post: lot378
  Pinebook Pro - Display cable broken? snokis 0 1,511 08-17-2021, 11:30 AM
Last Post: snokis
  pinebook pro dock display out mamboman777 0 1,504 07-29-2021, 10:41 AM
Last Post: mamboman777
  USB C dock with internal display mirrored to projector and one extended display jbrock 4 3,052 07-19-2021, 04:00 PM
Last Post: jbrock
