Bootloop after installing an ARM 32-bit program
Hello fellow piners!
I have a problem and kind of a workaround for it already, i case any of you face the same problem.
My Case:
i wrongfully installed a vpn client which offers only "Rasbian 32-bit" Support.
(I like to try/break things on purpose)
They provide a full arm.deb package which i installed and and the client works.
But then on the next reboot i get in a bootloop, seeing only the "OPEN SESAME" splash and then it reboots again.
(If anyone can offer me a good explanation why that happens, it would be much appreciated)
WORK-AROUND:
I noticed if you let it loop for 3-5 times with a MicroSD in the Slot (mine had already the new image on it) it eventually goes to your normal LightDM login. then you can remove the package and everything works again!
Does the VPN Client use any hooks or modifies something trivial?
I tried it with the wlan privacy switch OFF and it didn't work.
For now i'll configure my VPN manually, but an explanation would be very helpful!
(Or a package from my VPN provider arm 64-bit)
Thanks for reading!
Hello FBI,
I am not an actual hacker.
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,166 12-13-2023, 07:22 PM
Last Post: trillobite
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,206 11-28-2022, 05:03 PM
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,089 03-22-2022, 06:37 PM
Last Post: pentamassiv
  Installing debian on pinebook pro (deb installer/emmc) ljones 14 11,275 02-08-2022, 02:47 AM
Last Post: Humid Stylus
  Installing cinnamon on Manjaro PBP [SOLVED] quixote 1 2,243 05-09-2021, 01:39 PM
Last Post: quixote
  installing OS from SD to eMMC methods for flashing SD PineHead7 3 5,930 12-22-2020, 06:52 PM
Last Post: jiyong
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 17 19,439 11-19-2020, 03:16 AM
Last Post: FeMike
  Upgrading eMMC and Installing Majaro XFCD 20.06 lyssa 0 1,828 07-01-2020, 05:27 PM
Last Post: lyssa
  boots not after try installing arch definitiv. 3 5,356 06-17-2020, 04:06 PM
Last Post: definitiv.
  Installing Brother printer drivers on Manjaro dhosh 4 5,643 02-24-2020, 09:47 AM
