Installing cinnamon on Manjaro PBP [SOLVED]
This is for a user who just got a PBP (loves it Big Grin ) and before has used LinuxMint Cinnamon since forever.
Since he's used to Cinnamon, he wanted that as a DE, and I thought, "Easy. Go to Add/Remove software, find cinnamon-desktop, and install."
Well, that part was easy. But it keeps booting into KDE. I simply cannot find where you tell the system to use cinnamon. There's no option to choose DE at login (that I could see), and no setting that can be changed after it's booted.
There's got to be a way, right?   Huh   Help, please. Confused
OS: Mobian Bookworm, Phosh. Pinephone Braveheart from 2020-02-11
The commands here worked.
$ sudo pacman -S cinnamon
$ sudo pacman -S cinnamon-wallpapers cinnamon-sounds gnome-terminal parcellite
                    ##cinnamon-wallpapers and cinnamon-sounds were not available at whichever repo was hit
$ sudo pacman -S lightdm lightdm-slick-greeter lightdm-settings
$ sudo systemctl enable lightdm.service --force
The only significant difference, as far as I can tell, to a CLI install I tried earlier is that this one had the --force switch on the last command.
  Manjaro Sway Theme Broken Eighty8 1 279 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,751 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 328 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,139 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,212 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 891 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,019 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,969 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 765 08-18-2023, 02:06 AM
Last Post: juliamenendez
