Installing Brother printer drivers on Manjaro
I have gone around in circles trying to get a couple Brother printers to work on my network.  They are an MFC-J4620DW (color ink jet) and an JL-L2930DW.  Both are less than a year old.  The AUR builds end up with  the drivers 'not available for aarch64 architecture.  I've done some searches for ideas, but apparently, I'm not grasping something ... as all i end up with is my head spinning.  I'm not new to Linux, but am to Manjaro (usually use flavors of Ubuntu) ... I don't seem to be having too much trouble with Manjaro but apparently the aarch64 architecture is.
Thanks in advance.https://download.brother.com/welcome/doc101074/cv_eng_login_password_insertion_a.pdf
Dennis Hoshield
PBPro/ANSI/Manjaro
You will have to use airprint (ipp everywhere) or driverless,
I have made a number of posts about this
debian has 2 or 3 pages in their wiki
NOTE cups must be 2.2.4 or >, so will not work in stretch
when picking ppd,,, generic-ipp everywhere or generic-driverless
You have to get address right too,, harder if usb connected, designed for network
(02-23-2020, 08:52 PM)dhosh Wrote: I have gone around in circles trying to get a couple Brother printers to work on my network.  They are an MFC-J4620DW (color ink jet) and an JL-L2930DW.  Both are less than a year old.  The AUR builds end up with  the drivers 'not available for aarch64 architecture.  I've done some searches for ideas, but apparently, I'm not grasping something ... as all i end up with is my head spinning.  I'm not new to Linux, but am to Manjaro (usually use flavors of Ubuntu) ... I don't seem to be having too much trouble with Manjaro but apparently the aarch64 architecture is.
I took a look inside the AUR build file of the model of my Brother printer (which in my desktop Ubuntu works flawlessly). It seems to download some i368 binary RPM from Brother's website. So no good luck with that, maybe QEMU userland emulation is possible :/
Normally, for a lot of AUR packages that say that they don't support aarch64, it's possible to edit the build file and add 'aarch64' and it would work fine. But only if it's built from source, though.
I was able to get my Brother HL-2240 working for my PBP by using a ppd file from openprinting.org.  Check out their search page to see if you can find your printers (or earlier/similar models), and then try the listed ppd files via CUPS.
Is not the HL-2240 a rather older printer? Maybe 12-14 yrs old?
There are a few brother printers that have been reverse engineered,
and the filter driver compiled for aarch64 or armhf
These are mostly (all?) laser printers
When you print a test page, it shows ppd used, middle of page, 2/3 down
For a HL-2140, running under x86, this is filter driver
/usr/local/Brother/lpd/rawtobr2: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV),
  Manjaro Sway Theme Broken Eighty8 1 167 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,605 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 213 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,914 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 291 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 746 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,913 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,853 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 709 08-18-2023, 02:06 AM
Last Post: juliamenendez
