Pinebook missing screw from the factory
Hi all I have a problem with missing lid screw from the factory I've contakt the pinebook per email the same day they told me that I need to wait they will contact their hardware devision.. And I'm still waithing for answer... I just need the specs for the screw to be able to order some it really bugs me...  the screw is at the bottom side of the lid (shorter one it has longer ones too same head I'm happy they are all in place) if someone knows the type or the name of it please to share with me
(01-20-2020, 05:55 AM)tso4ev Wrote: Hi all I have a problem with missing lid screw from the factory I've contakt the pinebook per email the same day they told me that I need to wait they will contact their hardware devision.. And I'm still waithing for answer... I just need the specs for the screw to be able to order some it really bugs me...  the screw is at the bottom side of the lid (shorter one it has longer ones too same head I'm happy they are all in place) if someone knows the type or the name of it please to share with me
I , too, have been waiting for an answer about screw sizes.  After experimenting,  what worked for me were M2 flat head machine screws  (M2 is the size).
4mm for the short screws and 6 mm for the longer ones....
Its inexpensive to just buy a set of M2 screws--I think it will be easy to lose them...
Thank you for the information. I've updated the Wiki to include what we know;
Wiki - Pinebook Pro - Pinebook Pro Dimensions
As usual, feel free to correct, improve or comment, (good or politely bad).
Eventually I hope all information is available. Not that I plan on building my own Pinebook Pro. But if I want to modify it, details like this will help.
Arwen Evenstar
Princess of Rivendale
Screws, estimated dimensions, (until we can get confirmation)
8 x 6mm in length
2 x 4mm in length
they should be 6 x 6mm and
4 x 4 mm
I've place Order from aliexpress of 2 different sets of m2 when they arrive and I test it will confirm and share a link
Thank you
(01-20-2020, 01:19 PM)tso4ev Wrote: Screws, estimated dimensions, (until we can get confirmation)
   8 x 6mm in length
   2 x 4mm in length
4 x 4 mm
Done, thank you.
And, I added a note that the 4 shorter screws are used along the front edge. Might help someone putting it back together.
Arwen Evenstar
  Pinebook Pro Initial Impressions kunger 443 587,934 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,288 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 395 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 286 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 222 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 667 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 735 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,600 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,224 12-15-2023, 02:11 PM
