Baldur's Gate on Pinebook Pro
Hi, I've managed to get Baldur's Gate II running on Pinebook Pro with Manjaro. In order to achieve that you need to use the GemRB open-source engine. I've published a script which achieves that. Before running, you need to download the latest release from https://github.com/gemrb/gemrb/releases/tag/v0.8.6. Baldur's Gate is bundled with it's enhanced edition on GOG. You can extract it using innoextract, available in Manjaro repositories. I had issues with the git version, though it might have had to do with bad cmake flags. Please note that the script doesn't install the dependencies - check out the sources.
https://bitbucket.org/brzegorz/pinebookp...l_gemrb.sh
Sources:
http://gemrb.org/wiki/doku.php?id=installation
Things I had to correct in order to get it to work:
- Your installation should be in a folder without spaces, e.g. "BaldursGateII" instead of "Baldurs Gate II"
- cmake .. -DDISABLE_WERROR=1 -DSDL_BACKEND=SDL2 -DOPENGL_BACKEND=OPENGL -DSTATIC_LINK=enabled
    - I haven't checked if DISABLE_WERROR and SDL_BACKEND make a difference
   - OPENGL_BACKEND=GLES caused segfaults when starting the game for me
    - STATIC_LINK=enabled is needed for the game to compile. It might have to do with my Python installation, but, well, it works
- My gemrb.cfg: https://pastebin.com/LvcwRhzw. The annoying thing is that the one which is copied from build dir has wrong paths
- to run: gemrb -c gemrb.cfg
I'm working on the widescreen mod and testing how it actually works right now.
EDIT1: I've freed my friends and won an epic battle with Mephits on 640x480. Stuff seems to be working just fine.
EDIT2: I've added a script to install the widescreen mod. Mephits die twice, everything works: )
https://bitbucket.org/brzegorz/pinebookp...escreen.sh
  Debian on Pinebook Pro u974615 7 1,061 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,621 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,117 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,257 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,299 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,489 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,595 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 667 07-13-2023, 05:21 PM
Last Post: owaspfap
