Mainline Kernel 5.4 Solution
i managed to get Ayufans 5.4 Mainline Kernel to run.
The Kernel option for CONFIG_TMPFS needs to be activated prior compiling.
Besides that u can follow this guide https://forum.pine64.org/showthread.php?tid=6799
I also increased ramdisk_addr_r in the uboot shell and   since this https://nixos.wiki/wiki/NixOS_on_ARM/PINE64_ROCKPro64 Guide mentioned something about it but i am not sure if it is necessary.
Btw with this fix it still needs ages to boot since the dtbs is missing and some other stuff is very unoptimised. i also need around 2 min to login and couldnt get a keyboard working on the board directly.
Greetings Khaosgrille
I played around with the 5.4.0 kernel but the performance is beyond terrible. I am assuming ayufans 4.4 kernel got bunch of configurations to use the rockpro64 optimal. It works but i need around 2-10 min to boot, 2 min to login and it freezes every now and than. SSD is not recognized with the 5.4 Kernel.
  Freezes and kernel panics with Debian trixie jssfr 4 2,773 04-15-2026, 06:48 PM
Last Post: prahal
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 5,197 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 40,281 08-16-2023, 01:34 AM
Last Post: varac
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 5,923 06-16-2023, 10:54 AM
Last Post: CounterPillow
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 4,116 05-08-2022, 03:26 PM
Last Post: paralin1
  Kernel OOPs triggered by big writes to ext4 FS ajtravis 1 3,837 04-04-2022, 05:29 PM
Last Post: ajtravis
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 4,703 09-11-2021, 08:58 PM
Last Post: t4_4t
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,045 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  compiling a new kernel for overclocking on arch Mentaluproar 2 5,241 07-15-2021, 10:16 AM
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 5,879 07-14-2021, 02:37 PM
Last Post: TRS-80
