compiling a new kernel for overclocking on arch
I'm having a little trouble trying too understand how to make the kernel for an archlinuxARM image.  The last instruction I found here, which had make deb as a part of. the make command, doesnt make sense, and there isn't really a rockpro64 AUR entry for it so the normal makepkg method won't really work for me.
Has anyone done this before?
(07-14-2021, 11:35 PM)Mentaluproar Wrote: I'm having a little trouble trying too understand how to make the kernel for an archlinuxARM image.  The last instruction I found here, which had make deb as a part of. the make command, doesnt make sense, and there isn't really a rockpro64 AUR entry for it so the normal makepkg method won't really work for me.
Yup - (very) old intructions how to compile a kernel as well as overclock are here.
If you want a more modern kernel then probably start with the PinebookPro/Manjaro source but the overclocking guide I would imagine still applies.
Quote:Yup - (very) old intructions how to compile a kernel as well as overclock are here.
Look at step 7. It stops working there.
  Freezes and kernel panics with Debian trixie jssfr 4 4,288 04-15-2026, 06:48 PM
Last Post: prahal
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,259 09-22-2023, 04:27 AM
Last Post: diederik
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 7,097 06-16-2023, 10:54 AM
Last Post: CounterPillow
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 4,649 05-08-2022, 03:26 PM
Last Post: paralin1
  Kernel OOPs triggered by big writes to ext4 FS ajtravis 1 4,448 04-04-2022, 05:29 PM
Last Post: ajtravis
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 5,266 09-11-2021, 08:58 PM
Last Post: t4_4t
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,425 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 6,428 07-14-2021, 02:37 PM
Last Post: TRS-80
  ayufan kernel update unbootable TheHunter 2 6,138 03-12-2021, 05:17 PM
Last Post: LMM
  Kernel oops after big-ish writes gaeb 1 4,599 02-11-2021, 03:55 PM
Last Post: gaeb
