Other boot options than Sdcard for linux 5.x kernel?
I would like to use my Rockpro64 as a dockerplatform. Due to compatibility reasons I would like to use a 5.x linux kernel, and for reliability reasons I would like to boot from  something else than a SDCard.
So far I tried booting Armbian from eMMC, USB and NVMe but nothing worked. I'm using the uboot posted here:
https://github.com/sigmaris/u-boot/relea...ckpro64-ci
I tried a few others like debian as well, but nothing on 5.x kernel seems to work. From SDCard they all seem to work fine.
Could anyone point me to a possible solution?
Best regards,
MrA
(06-28-2021, 12:52 PM)MisterA Wrote: Hi,
Best regards,
MrA
I too failed to get Armbian or Manjaro to recognise my eMMC. But now Arch is perfectly feasible - as I write booting 5.13 kernel from eMMC. (See my post on pg 2 of that thread as well.)
All due respect, using some other u-boot (that did not come with Armbian) is not really "using Armbian."  lol
Armbian comes with u-boot, in fact such low level customizations are the very raison d'être for Armbian in the first place.
There is a special tool however for installing to other media than sd card, called nand-sata-install (which is also available from armbian-config).  So, just burn your image to sd card (making sure to take all usual precautions), boot into it, then use those tools to install to the eMMC (or wherever you like).
Cheers,
TRS-80
Protocols, not Platforms
  Freezes and kernel panics with Debian trixie jssfr 4 2,422 04-15-2026, 06:48 PM
Last Post: prahal
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 11 19,313 03-07-2026, 09:32 AM
  Boot/Shutdown on timer captainmorgan 8 14,256 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 5,022 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 6,983 07-14-2023, 04:22 AM
Last Post: hunderteins
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 5,744 06-16-2023, 10:54 AM
Last Post: CounterPillow
  Linux laptop does not detect the board when plugged in via USB soupy 1 7,071 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 boot questions misterc 3 5,839 01-13-2023, 06:21 PM
Last Post: misterc
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 3,585 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  RockPro64 linux console video mode callegar 0 2,512 09-06-2022, 02:32 PM
Last Post: callegar
