[OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel
[Image: skiff.png]
Megi kernel 5.17.x with ayufan patches merged in is now available for Rockpro64 w/ SkiffOS.
SkiffOS adds a configuration layering system to the Buildroot cross-compiler, which makes it easy to re-target applications to new hardware. Layers are merged together as specified in the SKIFF_CONFIG comma-separated environment variable.
As a basic example: SKIFF_CONFIG=pine64/rockpro64,core/gentoo starts Gentoo on a Odroid N2+ in a Docker container. You can ssh to the "core" user to enter the Gentoo environment.
The default configuration produces a minimal (~100Mb) in-RAM host OS with SSH and network connectivity, and includes a comprehensive set of debug tools. The host OS can be easily remotely updated with the push_image script, using rsync.
The "skiff/core" layer enables Docker ("apps/docker") and a default environment based on Ubuntu with a full graphical desktop environment. Others including "core/gentoo" and "core/dietpi" are available.
The SkiffOS host OS separates hardware-specific support from the containerized user environments, simplifying management of updates across multiple hardware combinations.
The guide for build + flash SD card on Rockpro64 and other boards (including Pinephone):
https://github.com/skiffos/SkiffOS/tree/.../rockpro64
[Image: xTpRsRz.png]
Note: this is a cross-compiler, you can build it on a faster machine & install to the Odroid. (No need to build on the device).
[Image: aTAmXwZ.png]
Updated to 5.17.5
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 7 3,836 11-20-2024, 03:53 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 122,083 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 694 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 1,687 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 4,736 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 2,395 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 26,702 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 101,834 08-11-2023, 11:13 AM
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 2,818 06-16-2023, 10:54 AM
Last Post: CounterPillow
  How to enable CoreSight ETM trace on RockPro64 shpark 0 1,293 05-21-2023, 11:34 PM
Last Post: shpark
