[solved] On default OS (Debian 9), lxqt breaks Chromium
I tried to install lxqt on the default OS of the pinebook pro (Debian 9).
Firstly it's complicated: you have to install openbox in addition to task-lxqt-desktop, which doesn't install by default (!), And you have to go through lightdm-gtk-greeter-settings to add a session selector. In addition, the default configuration is very poor: there are almost no icons.
Second, lxqt modifies the chromium configuration folder, so that it is impossible to connect to your Google account, because the browser is not "secure" (!?)
Fortunately I had synchronize my profile in the Google cloud.
So to solve the problem:
mv ~/.config/chromium ~/.config/chromium.back
restart chromium
Chromium recreated a configuration folder.
Connection to Google is again possible.
Then I syncronized my profile, so I didn't lose my extensions nor everything else.
I just had a security alert that a "new" browser had logged into my account, but obviously it was myself.
Pinebook Pro, standard config (Manjaro)
  Debian on Pinebook Pro u974615 7 1,053 03-31-2024, 10:11 AM
Last Post: u974615
  Nethunter default password failed lamlarryyyy 0 355 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,059 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,450 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,070 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,280 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,345 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,051 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,910 09-23-2022, 08:37 PM
Last Post: computerc
  Debian emmc installer db579 6 2,993 08-23-2022, 06:13 AM
Last Post: db579
