No POWER after installing Manjaro on microsd
Hi guys,
I hoping to get some assistance with my pinebook pro which no longer powers on.
I've been using the factory installed debian and thought i'd give manjaro a go.
I used the Manjaro-ARM-kde-plasma-pbpro-19.12.img.xz image and put it on my micro sd via etcher. After booting up on the micro sd the manjaro install continued (i chose user name, keyboard layout etc) then it rebooted
Since then I can't get my pinebook to power on with either the micro sd in or out (I was at least hoping debian would run without the micro sd).
I came across this thread but want to be I believe my situation is different (I thought I didn't write to eMMC)???
-update 1- since writing this post, I have been able to get the power light on (flashing, but nothing on screen).
-update 2- i've plugged in power and it boots now via debian. I will test further and report back
Many thanks
George
hmmm... i feel like an idiot but when I plugged in the charger cable I was able to boot again in debian and also complete the install of manjaro on the micro sd???
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,765 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 337 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,161 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 415 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 906 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,024 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,986 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 776 08-18-2023, 02:06 AM
Last Post: juliamenendez
