Hardening your Pinebook Pro
I think one of the best improvements with regards security would be to deliver images with disk encryption enabled. The password can be a default one then force users to change it...
@e-minguez, Lets make it clear to others, full disk encryption is "at rest". Meaning if an attacker / cracker gets in via network while the Pinebook Pro is booted, the full disk encryption does nothing to stop them from copying / damaging any file they can. (What I mean by any file they can, is if they got in as a normal user, they can only copy / damage files a normal user has access to.)
While I intend to use root OS encryption as well as swap encryption, normal hardening attempts to prevent remote access. Far more common loss of data compared to physical theft today.
Last, full disk encryption does not stop someone with physical access to the computer, (even if powered off), if they have the password. Or can guess it. (And in the case of hostile govenment agents, beat it out of the owner.)
Arwen Evenstar
Princess of Rivendale
One other thing that probably should be done, is re-create the host SSH keys. SSH host keys should be unique per host. From what I can tell, the default Debian comes with host SSH keys already created from July 11, 2019;
# ls -l ssh_host_*
-rw------- 1 root root  668 Jul 11 16:55 ssh_host_dsa_key
-rw-r--r-- 1 root root  609 Jul 11 16:55 ssh_host_dsa_key.pub
-rw------- 1 root root  227 Jul 11 16:55 ssh_host_ecdsa_key
-rw-r--r-- 1 root root  181 Jul 11 16:55 ssh_host_ecdsa_key.pub
-rw------- 1 root root  411 Jul 11 16:55 ssh_host_ed25519_key
-rw-r--r-- 1 root root  101 Jul 11 16:55 ssh_host_ed25519_key.pub
-rw------- 1 root root 1675 Jul 11 16:55 ssh_host_rsa_key
-rw-r--r-- 1 root root  401 Jul 11 16:55 ssh_host_rsa_key.pub
Plus, remove the in-secure DSA host key.
Here is how to do it.
As user "root", simply run the following commands. If you like, you can put the hostname in the comment, like "MyHost rsa hostkey".
cd /etc/ssh
rm ssh_host_*
ssh-keygen -t 4096 -t rsa -C "rsa hostkey" -f ./ssh_host_rsa_key
ssh-keygen -t 521 -t ecdsa -C "ecdsa hostkey" -f ./ssh_host_ecdsa_key
ssh-keygen -t ed25519 -C "ed25519 hostkey" -f ./ssh_host_ed25519_key
Note that you will be asked for a passphrase. Per SSH manual page, host keys must have an empty passphrase. Simply hit return when prompted, (twice per key).
Arwen Evenstar
Maybe there is a "bug" in the default debian image.
Normally host keys are generated at first boot with a clean image aka without *any* hostkeys.
Also please disable PAM in sshd.config, (I don't trust PAM modules)
after you have copied your pubkeys on your computer.
  Debian on Pinebook Pro u974615 7 1,062 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,621 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,130 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,257 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,299 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,489 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,596 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 667 07-13-2023, 05:21 PM
Last Post: owaspfap
