Rock64 lost connection after high I/O traffic
Hello Everybody, I´m new here and ask for help in this matter.
I have a Rock64 4G v2 and a tried it with many different Ubuntu bionic and Debian os, as:
-   Armbian_5.69_Rock64_Ubuntu_bionic_default_4.4.167
-   Armbian_5.90_Rock64_Ubuntu_bionic_default_4.4.182
-   Armbian_5.98_Rock64_Ubuntu_bionic_default_4.4.192
-   Armbian_5.98_Rock64_Debian_buster_default_4.4.192 (last one).
With all those os I get the same errors after dmesg: pls compare https://pastebin.com/0bxG6RC1
Do you think it is an hardware (memory) problem?
After normal boot and a while it get stuck and lost ssh or Ethernet connections.
I really don´t know what can I do with this SBC. Could yoo please help me?
How are you booting your system. Possibly a bad SD card. Also check out your power supply. Possibly under powered on boot. Also try changing your HDMI cable.
(11-12-2019, 03:39 PM)Rocklobster Wrote: How are you booting your system. Possibly a bad SD card. Also check out your power supply. Possibly under powered on boot. Also try changing your HDMI cable.
Thank you for reply. The System boots on a NEW flashed 16GB microSD card (SanDisk, A1 class). Before I had a corrupted 32GB microSD card of Samsung Pro Endurance. The power supply is still the EU Original one I've purchased from the Dealer in Germany. I've never used the Rock64 with Monitor and HMDI cable, but only on ssh Terminal.
Try connecting a HDMI monitor to the board and examine the boot screen.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 622 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 616 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,446 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,817 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 596 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 653 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,482 12-07-2022, 08:22 PM
Last Post: luminosity7
