emmc / sd or ssd?
   I have a question/remark concerning the "choice" between emmc / SD or ssd. Currently, the regular price for emmc of 64GB is rather in the same order of magnitude to a ssd of 120GB NVME. If I am not wrong, the SSD has a better performance than emmc, therefore, if it were possible to boot from PCIE, does it worth using emmc ? I read in the forum that many attempts has been done but end with a mix emmc for boot and ssd for root. @pine64 team : is there a really possibility to make the rockpro64 boot from PCIE ?
Best regards
My favorite is boot from sd-card and root system on an pcie nvme ssd.
For boot from ssd we need an working u-boot. At the moment not possible.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(02-21-2019, 12:59 PM)Bullet64 Wrote: My favorite is boot from sd-card and root system on an pcie nvme ssd.
I read your posts, and I think that this is the best solution for performance (thank you for having shared your experiences). That's what I am going to do !
What I can also try is a network boot (PXE) with a root on SSD. I almost succeeded to boot (it boots but with some problems after) with nfs but never tried with root on ssd.
Is it possible to boot with USB-C ? I have a case with PCIE to USB-C converter.
LMM
I tried USB3 with a key stick it is ok, but USB-C does not boot : power led not lit on the ssd
  Can i use this Emmc for Rockpro 64 Supratec 2 662 12-20-2023, 09:12 AM
  eMMC modules ajtravis 3 2,375 10-12-2022, 01:44 PM
Last Post: ajtravis
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,806 07-02-2022, 09:24 AM
Last Post: dkebler
  Flash to eMMC? Barugon 4 2,814 04-27-2022, 03:10 PM
Last Post: Barugon
  rockpro64 emmc GreyLinux 8 6,822 11-08-2021, 01:56 PM
Last Post: GreyLinux
  eMMC 128gb flailingeffort 1 2,581 01-18-2021, 04:42 AM
Last Post: Wizzard
  RockPro64 eMMC boot euu 4 7,344 08-24-2020, 11:07 PM
Last Post: t4_4t
  sw4 jumper for disabling eMMC boot / multiboot ChriChri 0 2,205 03-09-2020, 08:54 AM
Last Post: ChriChri
  Availability of 128GB eMMC ? Arwen 1 2,991 07-22-2019, 11:28 AM
Last Post: Arwen
  board not working with EMMC RockPro64Newbie 1 2,914 05-10-2019, 02:22 AM
Last Post: Unkn0wn
