04-27-2022, 12:35 PM
Is it possible to flash an image to eMMC without having to remove the module? Does Tow-Boot have any functionality that would help here?
Flash to eMMC?
04-27-2022, 01:29 PM
(04-27-2022, 12:35 PM)Barugon Wrote: Is it possible to flash an image to eMMC without having to remove the module? Does Tow-Boot have any functionality that would help here? No problem - just do it from an SDcard. You need to disable the eMMC during initial boot phase if it has something bootable on it as per the wiki.
(04-27-2022, 01:29 PM)dukla2000 Wrote: No problem - just do it from an SDcard. You need to disable the eMMC during initial boot phase if it has something bootable on it as per the wiki. So, I would need a bootable OS on the SD in order to DD to eMMC.
04-27-2022, 02:59 PM
Yes
for some reason my reply has to be longer than 3 chars before it will post
Can i use this Emmc for Rockpro 64 | Supratec | 2 | 639 |
12-20-2023, 09:12 AM Last Post: wdt |
eMMC modules | ajtravis | 3 | 2,329 |
10-12-2022, 01:44 PM Last Post: ajtravis |
Installation Debian on emmc: which U-Boot and where? | vongillus | 3 | 2,764 |
07-02-2022, 09:24 AM Last Post: dkebler |
rockpro64 emmc | GreyLinux | 8 | 6,769 |
11-08-2021, 01:56 PM Last Post: GreyLinux |
eMMC 128gb | flailingeffort | 1 | 2,564 |
01-18-2021, 04:42 AM Last Post: Wizzard |
RockPro64 eMMC boot | euu | 4 | 7,306 |
08-24-2020, 11:07 PM Last Post: t4_4t |
sw4 jumper for disabling eMMC boot / multiboot | ChriChri | 0 | 2,193 |
03-09-2020, 08:54 AM Last Post: ChriChri |
Availability of 128GB eMMC ? | Arwen | 1 | 2,973 |
07-22-2019, 11:28 AM Last Post: Arwen |
board not working with EMMC | RockPro64Newbie | 1 | 2,897 |
05-10-2019, 02:22 AM Last Post: Unkn0wn |
EMMC not booting while SD does. | Apokalypz | 29 | 32,269 |
03-10-2019, 04:12 AM Last Post: graham-r |
