sw4 jumper for disabling eMMC boot / multiboot
Ran into the following: I wanted to connect a little switch to choose between sdcard and emmc boot.
Didn't work: Open was fine - eMMC booted.
But closed seemed to boot from eMMC, too, but the archlinux didn't come up and got stuck while looking for its root device.
After some fiddling around, trying and reading serial console I tried a _jumper_.
Worked. As described in the layout the jumper shortens the clock of the emmc to ground. Is it possible that already a 5cm wire has too much resistance to disable the eMMC?
And if so, is there a smarter way to multiboot?
  Can i use this Emmc for Rockpro 64 Supratec 2 657 12-20-2023, 09:12 AM
  enble boot after power loss/restore dkebler 18 9,423 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,458 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 666 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,252 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,317 05-18-2023, 10:46 AM
  eMMC modules ajtravis 3 2,367 10-12-2022, 01:44 PM
Last Post: ajtravis
  u-boot locked on pine64pro ljones 1 1,548 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,186 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,150 07-19-2022, 10:48 PM
Last Post: hazz
