Pinebook Pro?
(07-23-2019, 03:06 AM)mamboman777 Wrote: Will I be able to pre order ansi keyboard?
In these initial batches going for sale on the 25th, all units will have ISO keyboards. The ANSI keyboard model will be available later. There's still a fee issues to work out with it.
Does remmina run well? I'm planning to order a PBP for web browsing, light coding and ssh/rdp/vnc sessions.
(07-24-2019, 04:05 AM)noisy Wrote: Does remmina run well? I'm planning to order a PBP for web browsing, light coding and ssh/rdp/vnc sessions.
Remmina runs well.
I use tigervnc on my 14" Pinebook to remote into my home computer, and it works surprisingly well.
(07-19-2019, 09:15 PM)Der Geist der Maschine Wrote:
(07-17-2019, 07:29 AM)Luke Wrote:
(07-17-2019, 03:45 AM)brent.thierens Wrote: Will we able to install other DE on this build (like Gnome Shell, KDE ...) or will that give problems with the hardware acceleration?
Of course, but getting the acceleration working (properly) with each DE is something you have to be ready to do on your own. I've got reasons to believe that Plasma shouldn't be too much of a challenge. [...]
I'm getting old. In my youth things where simple: Isn't that up to xorg probing the hardware and loading the right driver modules?
What do we get on the preinstalled Debian, anyway: xorg or wayland?
xorg - rk custom + @Mrfixit2001 tweeks to support glamor acceleration on the gpu. You can switch to armsoc driver too.
Can't this be merged to the mainline version of xorg?
(07-18-2019, 07:12 AM)mamboman777 Wrote: Greetings! I'm planning on purchasing a PBP.  I would like to use it as a daily work machine for email and web browsing, but I'm curious if it may be usable for my side gig.  I am a recording engineer.  I would need it to run jack+ardour to record up to 16 track simultaneously @ 44.1k. Does anyone see any reason this won't work? The storage world be a concern. I would probably place sessions and tracks on USB drives.
Audio recording in and of itself isn't a cpu-heavy task, so while the PBP doesn't have a ton of horsepower it will probably handle that alright.  Make sure your storage device can handle the throughput though.
Doing editing, however, is not something I would recommend.
I wonder where can i get the coupon
I'm a desperate "just after july 1" member.
It would be bodacious if I could order the Pinebook Pro now; for the manufacturer's longer term planning and for my state of mind.
Or do I not exist without a coupon?
  Pinebook Pro Initial Impressions kunger 443 596,546 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,368 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 451 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 340 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 326 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 262 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 734 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 811 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,759 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,371 12-15-2023, 02:11 PM
Users browsing this thread: 8 Guest(s)
