Pinebook Pro?
#51
I want one with Linux Mint. Ubuntu supports ARMv8, it should not be that hard to pull from mint repos.
#52
(02-05-2019, 04:38 PM)locoturko Wrote: I want one with Linux Mint. Ubuntu supports ARMv8, it should not be that hard to pull from mint repos.
I just checked and there is no arm64 packages for mint binaries...
http://packages.linuxmint.com/list.php?release=Tessa
#53
As a Mint user myself, I am going to guess that Mint has source packages as well, right?
If so, it should be possible to just build each required package from source?
I would love it if the Mint team had build's for Pinebook/Pinebook Pro, Ubuntu MATE would be nice, having Arch would also be a real treat.
#54
(02-05-2019, 07:27 PM)mzs.112000 Wrote: As a Mint user myself, I am going to guess that Mint has source packages as well, right?
Just pointing out that it's not as simple as just pointing apt at a new repository.
In the case of arm boards it's even messier because there is no bios to hook into for driving hardware, which why there is so many armbian images.
#55
I wonder why no one has came up with a standardized EFI system for ARM boards?
There needs to be an EFI firmware with ports for the major ARM systems, ideally it should also have a user-acessible UI just like a regular computer/laptop. Then, that would eliminate the issue of having so many images for different boards or different board variants, since the EFI would provide a standardized HAL for OS to hook into.... Installing new OS on an ARM-based laptop, SBC or PC would be as simple as installing one on an Intel computer.
#56
Stabbing in the dark, but I think it's because ARM is mostly used in embedded systems, and has only recently began being adopted into other purposes. It weren't too long ago that PowerPC was a growing contender in the server market (and briefly Apple devices), then disappeared.
Will the PineTab adopt the same SD-Card preferential boot? Personally prefer this approach, makes distrohopping really easy.
[ PHP Developer | Pinebook 1G | About me ]
#57
(02-06-2019, 03:24 PM)soupbowl Wrote: Stabbing in the dark, but I think it's because ARM is mostly used in embedded systems, and has only recently began being adopted into other purposes. It weren't too long ago that PowerPC was a growing contender in the server market (and briefly Apple devices), then disappeared.
Maybe they can use LibreBoot and Coreboot?
https://www.coreboot.org/
https://libreboot.org/
Either one would make things way easier for Linux and BSD distros to support ARM devices and PCs.
#58
I'm here because of the PCMag article, and others. I have been waiting for something like the pinebook pro for a long, long time. Kudos to you folks for achieving what has apparently been impossible for other companies! I eagerly await the moment I can get my hands on one and get to the precious bits inside!
#59
Also eagerly awaiting the Pro. Heard about it from the same articles that are floating around. Very interested in a great combination of price and performance lab machine built for linux from the ground up. Following thread for updates.
#60
You wouldn't be able to accelerate cinnamon (at least currently) so it would have to be mate edition.
  Pinebook Pro Initial Impressions kunger 443 594,539 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,344 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 428 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 327 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 311 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 245 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 705 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 790 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,719 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,329 12-15-2023, 02:11 PM
