0.7.8 Linux release from ayufan for Rock64
Star
Hello everyone,
ayufan marked 0.7.8 as the new Linux release for Rock64.
As always you can upgrade to newest release:
sudo apt update -y
sudo apt-get install linux-rock64 -y
If you encounter issues with this (or future 0.7.X builds) then report them in this thread or directly on github.
Enjoy!
How do I upgrade from previous stable?
> apt-get update -y
E: Repository 'http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease' changed its 'Origin' value from '' to 'GITHUB-AYUFAN-DEB-ayufan-rock64'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
linux-rock64 is already the newest version (0.6.44).
"man apt-secure" doesn't help me understanding what to do. Huh
I'm suddenly getting the following messages when I try sudo apt-get update and sudo apt-get upgrade. Any ideas? I have a 4GB RAM Rock64 with eMMC module installed (but no SD card installed). Everything was working fine until today and I tried the update.
I'm currently on "Linux rock64 4.4.126-rockchip-ayufan-239 #1 SMP Sun May 27 18:38:24 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux"
ERROR MESSAGES:-
The following packages have unmet dependencies:
linux-rock64 : Depends: u-boot-rockchip-rock64 (= 2017.09-rockchip-ayufan-1017-g7bd50d7e0f)
E: Unmet dependencies. Try using -f.
dpkg: error processing archive /var/cache/apt/archives/u-boot-rockchip-rock64_2017.09-rockchip-ayufan-1017-g7bd50d7e0f_all.deb (--unpack):
trying to overwrite '/usr/local/sbin/rock64_upgrade_bootloader.sh', which is also in package u-boot-rock64 0.6.59
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
(07-24-2018, 11:20 PM)LeoD Wrote: How do I upgrade from previous stable?
> apt-get update -y
i have exactly the same messages...
ayufan is aware of the problem and will address the issue.
(07-25-2018, 12:38 AM)Pagliacci Wrote: I'm currently on "Linux rock64 4.4.126-rockchip-ayufan-239 #1 SMP Sun May 27 18:38:24 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux"
ERROR MESSAGES:-
the new kernel depend on the highlighted package which is not found by apt in any of your configured sources.
The best is to look for this package in ayufan's repository with the exact same version number as given (but it has most probably been forgotten along the way), and report an issue to ayufan's github page directly if not found anywhere.
Also, take a look at any special setup which may help.
> apt-get update -y
Use "apt update" (not apt-get).
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
> apt-get update -y
Will update my initial post, thanks !
Can you explain and resolve dual "extlinux/extlinux.conf" ?
  • first on vfat (efi) partition /dev/mmcblk1p6 and seems to be ignored (finally mounted to /boot/efi/...)
  • second on ext4 partition /dev/mmcblk1p7 and used with kernel images (finally mounted on /)
The problem is in "recovery" states. You cannot simply modify "extlinux/extlinux.conf" bootparemeters from windows hosts (on locally attached sdcard) (for example "single" parameter for recovery, "drm.debug=0x3f" to debug hdmi/drm settings/problems ...).
Can you explain and resolve many DTS and other booting errors in booting process ?
Kernel does not seems to be reliable with so many errors.
And yes, ayufan rk3328-rock64.dts is more better then original from rochchip-linux-4.4 that always crashes booting process.
[    0.000000] rockchip_mmc_get_phase: invalid clk rate
[    0.140599] Invalid sched_group_energy for CPU0
[    0.140640] Invalid sched_group_energy for Cluster0
[    0.542636] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    0.542674] vcc_phy: no parameters
[    0.542967] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[    0.543062] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-sys[0]'
[    0.544051] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    0.544076] vcc_sd: regulator get failed, ret=-517
[    0.544129] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    0.544148] vcc_sd: unable to resolve supply
[    1.223069] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply from device tree
[    1.223092] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/host-port failed
[    1.223598] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply from device tree
[    1.223620] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed
[    1.224018] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up vbus-supply from device tree
[    1.224039] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up vbus-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed
[    1.224061] phy phy-ff450000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator
[    1.224959] rockchip-u3phy ff470000.usb3-phy: Looking up vbus-supply from device tree
[    1.224981] rockchip-u3phy ff470000.usb3-phy: Looking up vbus-supply property in node /usb3-phy@ff470000 failed
[    1.225004] rockchip-u3phy ff470000.usb3-phy: Failed to get VBUS supply regulator
[    1.225511] phy phy-ff470000.usb3-phy.2: Looking up phy-supply from device tree
[    1.225530] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed
[    1.225938] phy phy-ff470000.usb3-phy.3: Looking up phy-supply from device tree
[    1.225957] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed
[    1.228711] phy phy-ff430000.hdmiphy.4: Looking up phy-supply property in node /hdmiphy@ff430000 failed
[    1.231755] rk-vcodec vpu_combo: Looking up vcodec-supply from device tree
[    1.231778] rk-vcodec vpu_combo: Looking up vcodec-supply property in node /vpu_combo failed
[    1.231803] rk-vcodec vpu_combo: no regulator for vcodec
[    1.232124] rk-vcodec vpu_combo: failed on clk_get clk_cabac
[    1.232181] rk-vcodec vpu_combo: failed on clk_get clk_core
[    1.236518] rk-vcodec vpu_combo: could not find power_model node
[    1.375298] rockchip-drm display-subsystem: devfreq is not set
[    1.376328] rockchip-vop ff370000.vop: invalid resource
[    1.376858] rockchip-vop ff370000.vop: failed to get vop lut registers
[    1.377490] rockchip-vop ff370000.vop: invalid resource
[    1.377988] rockchip-vop ff370000.vop: failed to get vop cabc lut registers
[    1.378925] rockchip-vop ff370000.vop: unable to request PWM
[    1.386440] rockchip-drm display-subsystem: failed to parse display resources
[    1.617194] Unable to detect cache hierarchy for CPU 0
[    1.742725] dwc2 ff580000.usb: Looking up vusb_d-supply from device tree
[    1.742747] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed
[    1.742767] ff580000.usb supply vusb_d not found, using dummy regulator
[    1.743726] dwc2 ff580000.usb: Looking up vusb_a-supply from device tree
[    1.743745] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed
[    1.743760] ff580000.usb supply vusb_a not found, using dummy regulator
[    2.549955] vcc_sys: could not add device link regulator.5 err -2
[    2.552281] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    2.552323] vcc_sd: unable to resolve supply
[    2.563783] vcc_sys: could not add device link regulator.6 err -2
[    2.565637] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    2.565680] vcc_sd: unable to resolve supply
[    2.588346] vcc_sys: could not add device link regulator.7 err -2
[    2.590027] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree
[    2.590071] vcc_sd: unable to resolve supply
[    2.601410] vcc_sys: could not add device link regulator.8 err -2
[    2.625001] vcc_io: could not add device link regulator.9 err -2
[    2.639224] vcc_io: could not add device link regulator.10 err -2
[    2.653336] vcc_sys: could not add device link regulator.11 err -2
[    2.867433] cpu cpu0: Failed to get leakage
[    2.867501] cpu cpu0: Looking up cpu-supply from device tree
[    2.867602] cpu cpu0: Failed to get pvtm
[    2.919022] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ff520000[0]'
[    2.919032] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ff520000[0]'
[    2.919039] dwmmc_rockchip ff520000.dwmmc: using lookup tables for GPIO lookup
[    2.919049] dwmmc_rockchip ff520000.dwmmc: lookup for GPIO wp failed
[    2.967348] dwmmc_rockchip ff500000.dwmmc: using device tree for GPIO lookup
[    2.967356] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@ff500000[0]'
[    2.967397] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@ff500000[0]'
[    2.967408] dwmmc_rockchip ff500000.dwmmc: lookup for GPIO cd failed
[    2.967425] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ff500000[0]'
[    2.967431] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ff500000[0]'
[    2.967441] dwmmc_rockchip ff500000.dwmmc: lookup for GPIO wp failed
[    3.353038] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[    3.353051] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[    3.387771] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    3.387784] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    3.450384] of_dma_request_slave_channel: dma-names property of node '/serial@ff130000' missing or empty
[    3.456564] ttyS2 - failed to request DMA, use interrupt mode
[    3.830676] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    3.830681] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    3.923018] mali-utgard ff300000.gpu: Looking up mali-supply from device tree
[    3.923150] mali-utgard ff300000.gpu: Failed to get leakage
[    3.929522] mali-utgard ff300000.gpu: Looking up mali-supply from device tree
[    3.929604] vdd_logic: could not add device link ff300000.gpu err -17
[    3.929623] vdd_logic: Failed to create debugfs directory
[    3.929645] mali-utgard ff300000.gpu: Failed to get pvtm
[    4.047500] devfreq ff300000.gpu: Couldn't update frequency transition information.
Away
mcerveny: /boot/efi/extlinux/extlinux.conf is legacy file, which is gonna be removed. If you want to modify boot params change `/etc/default/extlinux`, here is the docs: https://github.com/ayufan-rock64/linux-b...xtlinux.md.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 622 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 616 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,448 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,821 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 596 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,757 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 653 05-27-2023, 06:11 AM
Last Post: Transportsicherung
