/dev/spidev0,0 on the Rock64 - Does anyone know how to enable it?
Please check connection again. I see GND connected to pin 18 and not pin 20 and other errors.
Do you have 4.2" or 4.2"b/c ?
I modified 4.2" (monochrome) python demo code. Do not press ctrl-c main.py should be done after 35 seconds.
.tar   eink42_sample.tar (Size: 120 KB / Downloads: 409)
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
Star
It freaking works!!! That is awesome. You are awesome :-)
Normally I don't do work on weekends, but this is so great :-))
I might/will have a couple of context-questions to grasp a few things and with your permission/help I'll write a doc how to use the eInk Displays in general in the following weeks.
Thanks again :-)
(09-09-2018, 05:26 AM)Kappuchino Wrote: It freaking works!!! That is awesome. You are awesome :-)
Thanks again :-)
Looking forward on your doc on eInk display.
Thanks again :-)
K
Did you get to writing up a doc on eInk Displays and the Rock64 ??
Would be great
Thanks to @mcerveny's posts in this thread, I was able to get a waveshare 2.7" e-paper hat working on my Rock64 v2, Armbian.
However, as mentioned above, due to the Rock64 pin out, it does not seem readily possible to utilize the display as a 'hat', as intended... which is a shame.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,367 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 616 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 610 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,397 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,624 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  how to use spidev0.1? jclab-joseph 2 2,287 02-06-2023, 04:43 PM
Last Post: monte
