ROCK64 NAS problem
I am trying to move my NAS from a RPi2 to a ROCK64 (4GB).  Everything is working except I can't get the drives to mount at startup.  In the RPi version, it was done by adding the drive info to the fstab file.  When I do that on the ROCK64, it hangs during boot.  I can mount them manually on the command line via Putty on my Windows 10 Desktop.  After they are mounted, everything is working well, but if something causes the ROCK64 to reboot, I can't see the drives on the LAN until I mount them.  I wrote a script to mount the four drives with one command line, but I would like to have them mount automatically at startup.  I am running stretch-mate-rock64-0.5.15-136-20171222-arm64.
(06-24-2018, 04:09 PM)wjburl Wrote: I am trying to move my NAS from a RPi2 to a ROCK64 (4GB).  Everything is working except I can't get the drives to mount at startup.  In the RPi version, it was done by adding the drive info to the fstab file.  When I do that on the ROCK64, it hangs during boot.  I can mount them manually on the command line via Putty on my Windows 10 Desktop.  After they are mounted, everything is working well, but if something causes the ROCK64 to reboot, I can't see the drives on the LAN until I mount them.  I wrote a script to mount the four drives with one command line, but I would like to have them mount automatically at startup.  I am running stretch-mate-rock64-0.5.15-136-20171222-arm64.
That should not be a problem. Show us the content of your /etc/fstab and /boot/efi/extlinux/extlinux.conf
rontant, thanks for responding.
Since I made the original post, I gave up and installed Open Media Vault and that is working well. I don't think I'll revisit the original project. I guess I need to close this thread. This is my 2nd ROCK64 SBC and it is really outperforming my RPi2 by an order of magnitude.
Since I've overwritten the SD card, I can't I don't the data in /boot/efi/extlinux/extlinux.conf. The info I added to /etc/fstab was:
UUID=2291d8b3-ef45-469c-aa97-3c9fafa86f85 /media/OldIomegaDrive ext4 defaults,user,exec 0 0
UUID=0bc03e5c-4f6a-4b42-ab5b-ee62f191e328 /media/TCMMovies ext4 defaults,user,exec 0 0
UUID=05f8302e-3a6a-49db-99d1-00c4d6302425 /media/DriveDBackup ext4 defaults,user,exec 0 0
UUID=81e17742-2be9-42e1-888d-ad4cfea1c206 /media/Seagate5TBdrive ext4 defaults,user,exec 0 0
Sorry, did not see this before, but I believe in making life easy and I use Webmin to configure my Rock64 home server, it handles all mounting etc.. May be worth a look. I have never used Open Media Vault, so hope it is working well for you.
stealthbanana, Thanks. It took me a few attempts to get OMV setup the way I wanted, but it has been working well since. One issue I had was that my HDDs already had data and OMV wants to format the drives and start over. It doesn't let you share an entire drive, so I had to move the contents of a drive to a folder and share that folder. Now that it is working, I'm hesitant to try another option. My Rock64 is considerably faster than the RPi 2 I had been using.
It can produce a bit of messy output on the command line, but you can use CRON to do this pretty much bullet proof!
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,370 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 616 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 612 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,408 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,641 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,437 12-07-2022, 08:22 PM
Last Post: luminosity7
