[Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE
#81
@Luke i think with
Quote:u-boot for the rock64 is still being developed? is there plans to support this use case in the future?
He wants to know, if you will Support Booting from USB (and not just SD card)
#82
(07-20-2018, 06:55 AM)gigagames Wrote: @Luke i think with
In fact i was refering to the dual boot i was asking before but he already answered that part...
#83
Eventually got round to trying it on my Rock64, all I can say is awesome work for an alpha. most things seem to work pretty flawlessly, the problems I did note were mainly down to the controllers, would only recognise a wired Xbox 630 controller, none of my cheap USB SNES controllers, homemade USB arcade controller or Bluetooth 8bitdo would work. The wired controllers were being picked up by the system (ssh's into the box and had a bole about) but info not reaching emulationstation. Limited keyboard and settings available. But hey, it's alpha, I hope these will be sorted soon. Most MAME worked well, Playstation was flawless, N64, well, graphic glitches.
One thing that utterly blew me away was transferring roms, Gigabit ethernet v old Raspberry pi makes all the difference in setting up.
Keep up the excellent work.
#84
Hello Luke,
First, great work !
I've tried the Alpha version in GitHub.
I'm using a monitor DVI. So I have a cable adaptor HDMI > DVI.
For the sound I would like to use the A/V jack.
In the audio settign I've only HDMI. I've tried to force "jack" manually the recalbox conf file. It doesn't work.
To be sure it was not a hardware issue, I've tried with other linux distri, and lakka, it works fine.
(I did not try with a HDMI monitor).
Any idea about this ? (On the video you've put tho show your work on Recalbox/Rock64 there was no sound as well).
Best regards !!
#85
stealthbanana,
Yes, the alpha has a limited controller compatibility. Beta will be much better in this respect.
pascal06n,
Indeed, the jack doesn't work on the alpha image and there is no easy way to get it working. Obviously it will work nicely on our upcoming beta - just hang tight. The alpha is there really just for testing and as a proof of concept.
Thanks Smile
#86
Awesome to see!
#87
I'm not seeing anything in the github with the exception of a text file. Is this still being actively worked on?
#88
(07-25-2018, 01:25 PM)KryPtAlIvIaN Wrote: I'm not seeing anything in the github with the exception of a text file. Is this still being actively worked on?
This link ? https://github.com/mrfixit2001/recalbox_rock64/releases
Of course it being worked on Smile Beta incoming soon - 3 months of hard work, sweat and tears....
#89
I can't wait anymore... Cry
#90
(07-25-2018, 02:19 PM)Danielsan Wrote: I can't wait anymore... Cry
Just to explain what is happening. We've got a completed build, but the issue is that it doesn't boot on some boards (kernel panic) while it boots on others. This is really what we've been troubleshooting and debugging for quite some time - nearly a month. But we're there now in terms of stability. Just some finishing touches. Thank you for your patience Wink
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 188 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,415 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 370 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 674 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 656 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,724 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 193,063 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 627 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 677 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,340 12-07-2022, 08:22 PM
Last Post: luminosity7
Users browsing this thread: 8 Guest(s)
