[Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE
#31
Xbox One (2 pads old/original - no 3.5mm jack) - pad detected - doesn't recognise key strokes - unable to configure
Xbox One Elite (2 pads) - pad detected - doesn't recognise key strokes - unable to configure
PS4 pad over USB (2 pads) - pad not detected
PS4 pad over BlueTooth - pad paired and detected - doesn't recognise key strokes - unable to configure
PS3 pad over USB (2 pads) - pad not detected
Keyboard (multiple) - detected as default controller - configure and play all fine
Everything I've tested so far worked great
...except N64
Small and with textures messed up.
...but in full speed.
Smash Bros.[Image: 808f8bd384ddc9839de3d7bf28e58420.jpg]
Scrapper works great!!
Amstrad demo game is either out is resolution or hanged Rock.
As for alpha, I'm impressed.
Rock64 + recallbox has better first impression than Raspberry 3 + Retropie.
Wysłane z mojego Redmi Note 4 przy użyciu Tapatalka
#32
(05-01-2018, 02:58 PM)S3phi40T Wrote: Xbox One (2 pads old/original - no 3.5mm jack) - pad detected - doesn't recognise key strokes - unable to configure
...except N64
Thank you for the testing and feedback!!!
A few tips - in the recalbox menu under advanced you can select what default emulator and core you want to use for each system. And under each rom's meta data you can even specify a different emulator and core just for that rom. Not all roms will perform the same on the same core, that's why why I included as many as possible for n64.
For the gamepads, see if you get different results if you plug them in before you boot. I think I remember reading that sometimes recalbox doesn't pick them up right if you plug them in while it's already running.
#33
Also just FYI, I just checked and libnfs is already on the image. Smile
#34
...except N64
Please try the following:
nano /recalbox/share/system/configs/mupen64/gles2n64rom.conf
and edit out the forced resolutions of the games you're trying to play.
[edit] for reference, could you also try Mariokart64 and see if that plays full screen? (it should)
[edit 2] also could you try editing
nano /recalbox/share/system/configs/mupen64/gles2n64.conf
and changing all settings - including Framebuffer and VI - to 1080p
Dzięki.
#35
Eventually I got a 64GB flashcard and I flashed Recalbox, it started however the booting is pretty messy with a lot of issue about ext2/3 partitions... I figured out that it was normal because the alpha state. I confirm that my gamepad works out of the box with Recalbox for R64, thanks!
#36
Danielsan, yep thats normal (for now) - will be dealt with eventually. By Beta no doubt.
S3phi40T, I can confirm the issue with Xbox 1 and PS4 BT gamepads.
#37
Dualshock 4 works with after you configure it manually with bluetoothctl
3D PS1 games aren't going too well. Do you anticipate being able to improve performance with future updates, or is that just the hardware's limit?
It's possible it's throttling because I don't have a heatsink on. I bought one and will install it to see if that helps.
#38
Hi, I can't see the N64 emulator neither I find a way to download the core...
Is there anything else I have to do to enable the N64?
PSX is silky smooth for me. [edit] Even with the enhanced resolution option ticked. Are you using any shaders ?
Could you please enable FPS counter and report the FPS in Tekken 3 please? I literally haven't had a single game dip below its intended framerate, so something is not right.
As for N64 you need games in .z64 format (not .zip) - I suspect thats why you're not 'seeing' the emulator.
Logs please! Otherwise its a guessing game...
#40
Where are stored the logs? I can enter through ssh and providing them.
Unfortunately my PSX emulation is pretty awful, very poor performance, and after copied the bios files the video doesn't work properly I get a black screen while the music run from the speaker.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 187 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,415 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 367 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 672 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 653 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,720 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 192,881 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 626 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 676 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,316 12-07-2022, 08:22 PM
Last Post: luminosity7
