bionic 4.4.120-rockchip-aynfan-209 scp problem on large file
whenever i try to use scp to transfer a large file this happens:
sftp> put configs_all.tar.gz
Uploading configs_all.tar.gz to /home/rock64/configs_all.tar.gz
Failed to set the permissions or timestamp on the destination file: The operation was aborted because the channel closed.
The sftp operation was aborted.
does not happen with small files
tried restarting sshd
service sshd restart
but get same error
opened bug report on this:
https://github.com/ayufan-rock64/linux-build/issues/155
  problem with debian emmc boot G4zCDzWb 10 30,540 11-01-2024, 04:32 PM
Last Post: bits
  Rock64 Debian 11 (Bullseye) install problem jbize 15 24,219 10-12-2023, 05:14 PM
Last Post: tpaul
  External hard drive problem k8Va 17 36,062 03-09-2021, 02:31 PM
Last Post: calinb
  Arch Linux Arm - external RTC problem max 1 5,300 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 10,952 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 8,511 05-06-2020, 11:29 PM
Last Post: deta
  armbian / bionic - hdmi to vga not functioning on newer5.4 kapqa 1 5,464 03-31-2020, 07:19 PM
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 3,602 02-05-2020, 10:58 PM
Last Post: dkebler
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 7,163 01-20-2020, 12:25 PM
Last Post: kf5zmi
Bug mpph264enc output doesn't work on bionic rompelstompel 11 28,915 11-15-2019, 10:00 AM
Last Post: gounthar
