mmc0: error -110
root@rock64:~# cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
root@rock64:~# uname -a
Linux rock64 4.4.77-rockchip-ayufan-136 #1 SMP Thu Oct 12 09:14:48 UTC 2017 aarch64 GNU/Linux
root@rock64:~#
getting these errors on the console on a periodic basis: Sad
root@rock64:~# bash
root@rock64:~# [  354.386841] mmc0: switch to bus width 8 failed
[  354.401069] mmc0: mmc_select_hs200 failed, error -110
[  354.401897] mmc0: error -110 whilst initialising MMC card
found url's that are related:
https://patchwork.kernel.org/patch/9161131/
https://github.com/raspberrypi/linux/issues/280
using toshiba brand microssd
are you booting from eMMC or sdcard?
from sd card, it's a toshiba unlike the rest of my sd's that are mainly sandisk, i might try putting the same os on a sandisk sd and see if i still get the errors.
The error you posted is related to the mmc bus where the eMMC is on, not regarding the mmc bus where the sdcard is.... do you have a eMMC module on the board?
yes i have a 16gb emmc i got thru ameridroid (https://ameridroid.com/products/emmc-module), have the jumper in place to bypass it during the boot.
wih the jumper out it does successfully boot into debian stretch, will try pul the jumper and boot from emmc to see if i get the same errors.
If you leave the jumper on until Linux boots, the error is expected, since the jumper disables eMMC clock...
i rebooted the sdcard with the jumper for the installed emmc pulled off 2 seconds after booting. Error is no longer present,so your suggestion works.
As a bonus now run fsck on mmc0 and fix some errors it would show when booting from emmc.
  opemmediavault plugin error on "Check" clach04 0 6,488 04-21-2020, 10:13 PM
Last Post: clach04
  Gpio error wile using GPIOtest.py Aditya Rastogi 0 3,192 01-31-2019, 02:41 AM
Last Post: Aditya Rastogi
  gstreamer error sdarktemplar 1 4,851 08-02-2018, 11:08 PM
  docker contaainer error on "docker login" edwinbmiller 0 2,732 06-18-2018, 10:08 AM
Last Post: edwinbmiller
  Apt-get update duplicate entry error Jxck 1 5,250 06-02-2018, 02:26 PM
Last Post: evilbunny
  Error building Rock 64 kernel Bapple 3 7,384 02-13-2018, 08:23 AM
Last Post: xalius
Question LoadTrustBL error when booting pedroz 0 2,908 02-09-2018, 08:35 AM
Last Post: pedroz
  Error when installing some packages - Installing new rk3328-rock64.dtb. msg thewonderer 0 3,422 02-07-2018, 05:22 AM
Last Post: thewonderer
  need some help with a dpkg error dkryder 0 2,730 12-25-2017, 03:09 PM
Last Post: dkryder
  Ayufun Pre-Release Repo Error jl_678 0 2,657 11-17-2017, 02:33 PM
Last Post: jl_678
