Apt-get update duplicate entry error
I don't know a lot about Linux but when i run apt-get update on R64 on OMV i get this.
W: Duplicate sources.list entry http://packages.openmediavault.org/public/ erasmus/main arm64 Packages (/var/lib/apt/lists/packages.openmediavault.org_public_dists_erasmus_main_binary-arm64_Packages)
W: Duplicate sources.list entry http://packages.openmediavault.org/public/ erasmus/main armhf Packages (/var/lib/apt/lists/packages.openmediavault.org_public_dists_erasmus_main_binary-armhf_Packages)
W: You may want to run apt-get update to correct these problems
I've looked this up but cant figure out how to fix it.
(06-02-2018, 11:26 AM)Jxck Wrote: I don't know a lot about Linux but when i run apt-get update on R64 on OMV i get this.
cd /etc/apt
grep -rl packages.openmediavault.org .
The above should show which files the contain packages.openmediavault.org and then it's just a matter of using nano to edit one or more to remove the above warning
  How to update/compile Debian 12.5? Wizardknight 2 208 03-14-2024, 05:30 AM
Last Post: diederik
  Spinlock Lock after Firmware Update Watcher 4 3,958 02-18-2021, 08:52 PM
Last Post: Rocklobster
  How can I update from Ubuntu 18 to Ubuntu 20? gedas07 3 4,010 10-04-2020, 10:02 PM
Last Post: tomarm
  opemmediavault plugin error on "Check" clach04 0 4,496 04-21-2020, 10:13 PM
Last Post: clach04
  Plex update on rock64 croquin 1 3,489 03-30-2019, 12:36 PM
Last Post: pfworks
  Cant update package libgl1-mesa-dri scalextrix 2 4,172 02-16-2019, 06:20 AM
Last Post: scalextrix
  Gpio error wile using GPIOtest.py Aditya Rastogi 0 1,867 01-31-2019, 02:41 AM
Last Post: Aditya Rastogi
  OpenMediaVault fails to update S265 3 9,152 08-23-2018, 06:28 AM
Last Post: S265
  gstreamer error sdarktemplar 1 2,714 08-02-2018, 11:08 PM
  docker contaainer error on "docker login" edwinbmiller 0 1,553 06-18-2018, 10:08 AM
Last Post: edwinbmiller
