Gpio error wile using GPIOtest.py
Greetings,
Well received my board yesterday. Tried to use GPIO in a small python code used library from https://github.com/Leapo/Rock64-R64.GPIO. But even the test file in it shows error.  Looking for help need to finish my college project asap.
import R64.GPIO as GPIO
from time import sleep
print("Testing R64.GPIO Module...")
# Test Variables
print("")
print("Module Variables:")
print("Name           Value")
print("----           -----")
print("GPIO.ROCK      " + str(GPIO.ROCK))
print("GPIO.BOARD     " + str(GPIO.BOARD))
print("GPIO.BCM       " + str(GPIO.BCM))
print("GPIO.OUT       " + str(GPIO.OUT))
print("GPIO.IN        " + str(GPIO.IN))
print("GPIO.HIGH      " + str(GPIO.HIGH))
print("GPIO.LOW       " + str(GPIO.LOW))
print("GPIO.PUD_UP    " + str(GPIO.PUD_UP))
print("GPIO.PUD_DOWN  " + str(GPIO.PUD_DOWN))
print("GPIO.VERSION   " + str(GPIO.VERSION))
print("GPIO.RPI_INFO  " + str(GPIO.RPI_INFO))
# Set Variables
var_gpio_out = 16
var_gpio_in = 18
# GPIO Setup
GPIO.setwarnings(True)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(var_gpio_out, GPIO.OUT, initial=GPIO.HIGH)       # Set up GPIO as an output, with an initial state of HIGH
GPIO.setup(var_gpio_in, GPIO.IN, pull_up_down=GPIO.PUD_UP)  # Set up GPIO as an input, pullup enabled
# Test Output
print("")
print("Testing GPIO Input/Output:")
var_gpio_state = GPIO.input(var_gpio_out)                   # Return state of GPIO
print("Output State : " + str(var_gpio_state))              # Print results
sleep(1)
GPIO.output(var_gpio_out, GPIO.LOW)                         # Set GPIO to LOW
# Test Input
var_gpio_state = GPIO.input(var_gpio_in)                    # Return state of GPIO
print("Input State  : " + str(var_gpio_state))              # Print results
sleep(0.5)
# Test interrupt
print("")
print("Waiting 3 seconds for interrupt...")
var_interrupt = GPIO.wait_for_edge(var_gpio_in, GPIO.FALLING, timeout=3000)
if var_interrupt is None:
    print("Timeout!")
else:
    print("Detected!")
# Test PWM Output
p=GPIO.PWM(var_gpio_out, 60)                                # Create PWM object/instance
print("")
print("Testing PWM Output - DutyCycle - High Precision:")
print("60Hz at 50% duty cycle for 1 second")
p.start(50)
sleep(1)
print("60Hz at 25% duty cycle for 1 second")
p.ChangeDutyCycle(25)
sleep(1)
print("60Hz at 10% duty cycle for 1 second")
p.ChangeDutyCycle(10)
sleep(1)
print("60Hz at  1% duty cycle for 1 second")
p.ChangeDutyCycle(1)
sleep(1)
p.stop()
print("")
print("Testing PWM Output - DutyCycle - Low Precision:")
p.start(50, pwm_precision=GPIO.LOW)
sleep(1)
sleep(1)
sleep(1)
sleep(1)
p.stop()
print("")
print("Testing PWM Output - Frequency - Low Precision:")
sleep(1)
print("30Hz at 50% duty cycle for 1 second")
p.ChangeFrequency(30)
sleep(1)
print("20Hz at 50% duty cycle for 1 second")
p.ChangeFrequency(20)
sleep(1)
print("10Hz at 50% duty cycle for 1 second")
p.ChangeFrequency(10)
sleep(1)
p.stop()
GPIO.cleanup([var_gpio_in, var_gpio_out])                   # Perform cleanup on specified GPIOs
print("")
print("Test Complete")
###########OUTPUT################
Module Variables:
Name           Value
GPIO.ROCK      ROCK
GPIO.BOARD     BOARD
GPIO.BCM       BCM
GPIO.OUT       out
GPIO.IN        in
GPIO.HIGH      1
GPIO.LOW       0
GPIO.PUD_UP    0
GPIO.PUD_DOWN  1
GPIO.VERSION   0.6.3
GPIO.RPI_INFO  {'P1_REVISION': 3, 'RAM': '1024M', 'REVISION': 'a22082', 'TYPE': 'Pi 3 Model B', 'PROCESSOR': 'BCM2837', 'MANUFACTURER': 'Embest'}
Error: Unable to export GPIO
Error: Unable to set GPIO direction
You must setup() the GPIO channel (BOARD 27) first
Output State : None
You must setup() the GPIO channel (BOARD 27) as an output first
You must setup() the GPIO channel (BOARD 32) first
Input State  : None
You must setup() the GPIO channel (BOARD 32) as an input first
Timeout!
Traceback (most recent call last):
 File "R64-GPIO-test.py", line 71, in <module>
   p.start(50)
 File "/home/rock64/camcode/R64/_GPIO.py", line 351, in start
   self.pwm_calc()
 File "/home/rock64/camcode/R64/_GPIO.py", line 368, in pwm_calc
   self.sleep_low = (1.0 / self.freq) * ((100 - self.dutycycle) / 100.0)
AttributeError: PWM instance has no attribute 'freq'
  opemmediavault plugin error on "Check" clach04 0 4,617 04-21-2020, 10:13 PM
Last Post: clach04
  Memory addresses of GPIO pins AckRite 3 4,960 10-23-2018, 03:18 PM
Last Post: AckRite
  gstreamer error sdarktemplar 1 2,782 08-02-2018, 11:08 PM
  GPIO indicators via DTB Mentaluproar 0 1,483 07-10-2018, 04:58 PM
Last Post: Mentaluproar
  docker contaainer error on "docker login" edwinbmiller 0 1,589 06-18-2018, 10:08 AM
Last Post: edwinbmiller
  Apt-get update duplicate entry error Jxck 1 3,024 06-02-2018, 02:26 PM
Last Post: evilbunny
  mmc0: error -110 edwinbmiller 6 7,094 03-29-2018, 12:44 PM
  Onboard LEDs connected to the RK805-1 out1 and out2 GPIO pins prof7bit 8 6,633 03-03-2018, 02:58 PM
Last Post: prof7bit
  Error building Rock 64 kernel Bapple 3 4,648 02-13-2018, 08:23 AM
Last Post: xalius
Question LoadTrustBL error when booting pedroz 0 1,635 02-09-2018, 08:35 AM
Last Post: pedroz
