slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#81
Will you keep updating 4.4.y kernel in the future?
As you mentioned that for now, 4.4.y kernel is maturer, at least in terms of video playback, compare with 5.8.y kernel right?
it is, but the developers are porting from 4.4.y to 4.19.y.
Yes so far 4.4.y is updated and supported.
Still, a lot has been done to play videos at 5.x, but so far I haven't really tried it.
donation   slarm64
judging by the changes in the kernel repository, the rockchip team switched from the 4.4.y branch to 4.19.y, a test build:
kernel 4.19.153
slarm64-current-aarch64-base-rootfs-20201023-4.19.153-rock64-build-20201029.img.zst
slarm64-current-aarch64-base-rootfs-20201023-4.19.153-rock64-build-20201029.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201023-4.19.153-rock64-build-20201029.img.zst
slarm64-current-aarch64-xfce-rootfs-20201023-4.19.153-rock64-build-20201029.img.zst.md5
donation   slarm64
update:
slarm64-current-aarch64-base-rootfs-20201023-4.4.241-rock64-build-20201031.img.zst
slarm64-current-aarch64-base-rootfs-20201023-4.4.241-rock64-build-20201031.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201023-4.4.241-rock64-build-20201031.img.zst
slarm64-current-aarch64-xfce-rootfs-20201023-4.4.241-rock64-build-20201031.img.zst.md5
donation   slarm64
kernel 5.9.3
slarm64-current-aarch64-base-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst
slarm64-current-aarch64-base-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst
slarm64-current-aarch64-xfce-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst.md5
donation   slarm64
@mara,
While I tried for a while and failed to find the unzip package of slarm64, can you help me on how to install it? Or I will have to compile it from sources?
(11-22-2020, 12:30 AM)Enig123 Wrote: @mara,
here is the description by appointment README.TXT
zstdcat slarm64-current-aarch64-xfce-rootfs-20201023-5.9.3-rock64-build-20201102.img.zst > /dev/mmcblk0
donation   slarm64
@mara,
I couldn't find logrotate tool with the image. Will you please give me some hint/reference where I can get start at?
(11-22-2020, 10:20 PM)Enig123 Wrote: @mara,
what image are you using base / xfce?
if you have slackpkg configured, run:
slackpkg install logrotate
if not configured, download the package and run logrotate-3.17.0-aarch64-1.txz and run:
installpkg logrotate-3.17.0-aarch64-1.txz
donation   slarm64
Thank you for your quick help. BTW, I am using the base image, and the slackpkg installed from the current branch does not work as expected somehow. It kept asking for the correct pgp key.
Perhaps I installed the wrong version of slackpkg?
Edit: Another question is for how to unzip a .zip file, which usually use package named "unzip" in most Linux distributions.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 622 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 616 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,444 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 595 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 653 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,481 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 939 08-29-2022, 01:22 PM
Last Post: ramprasad
