02-19-2019, 01:59 AM
slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
06-22-2019, 11:33 AM
updated kernel (ayufan 4.4.167-1213)
kernel for slarm64: kernel-firmware-rk3328-4.4.183-aarch64-1mara.txz kernel-headers-rk3328-4.4.183-aarch64-1mara.txz kernel-modules-rk3328-4.4.183-aarch64-1mara.txz kernel-rk3328-4.4.183-aarch64-1mara.txz update packages: 1. download all listed files 2. sudo upgradepkg kernel-*.txz
06-23-2019, 11:44 AM
update:
- kernel 4.4.183 - update all packages Sat Jun 22 19:14:18 UTC 2019 slarm64-current-aarch64-base-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz slarm64-current-aarch64-base-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz.md5 slarm64-current-aarch64-xfce-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz slarm64-current-aarch64-xfce-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz.md5
07-08-2019, 01:50 PM
(07-02-2019, 08:16 PM)pineadmin Wrote: Updated Slackware Aarch64 Miniroot (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer. I installed the XFCE version. The system hung repeatedly. The first two times during initial start-up, when resizing the sd card, than later on when the mouse was moved in the XFCE session. I think I tried the Miniroot version, too, that also hung. I tried different sd cards to make sure that was not an issue. I used etcher to install the image. I used to have a PC-based slackware router that I wanted to reimplement on the rock64. Unfortunatelly, I had to go with Armbian stretch at the end, because I could not use slackware, but I would like to go back to slackware if possible. How stable/reliable slackware on the rock64? Have you had good feedback? I'll try the next release. When will you have it? Thanks, Karl
07-08-2019, 08:26 PM
(07-08-2019, 01:50 PM)KarlF Wrote:(07-02-2019, 08:16 PM)pineadmin Wrote: Updated Slackware Aarch64 Miniroot (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer. Please ensure the Micro SD Card is UHS-1 class. If used lower class such as Class 2 Micro SD Card is too slow to use and can get the whole system runs in to low performance or sometimes crash. Thanks, pineadmin....
07-08-2019, 10:51 PM
(07-08-2019, 08:26 PM)pineadmin Wrote:(07-08-2019, 01:50 PM)KarlF Wrote:(07-02-2019, 08:16 PM)pineadmin Wrote: Updated Slackware Aarch64 Miniroot (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer. Quote:I installed the XFCE version. The system hung repeatedly. The first two times during initial start-up, when resizing the sd card, than later on when the mouse was moved in the XFCE session. I think I tried the Miniroot version, too, that also hung. I tried different sd cards to make sure that was not an issue. I used etcher to install the image. I will look at performance over a long period. while the problem of the correct booting and operation of the system from the SDcard with the eMMC module connected is noticed. when disconnecting the eMMC boot and works fine
07-09-2019, 02:14 PM
(07-09-2019, 11:41 AM)mara Wrote:Quote:I installed the XFCE version. The system hung repeatedly. The first two times during initial start-up, when resizing the sd card, than later on when the mouse was moved in the XFCE session. I think I tried the Miniroot version, too, that also hung. I tried different sd cards to make sure that was not an issue. I used etcher to install the image. I don't have an eMMC module. I'll give it another try with another SD card, and if that doesn't work, I'll have to throw in the towel.
07-10-2019, 08:59 AM
KarlF,
Left the board to work the day the image of the sfke, no problems were detected, SDCard samsung SD EVO PLUS 32Gb. |
irradium (based on crux linux) Rock64 riscv64, aarch64 | mara | 0 | 152 |
03-24-2024, 01:07 PM Last Post: mara |
Rock64 v2 - did not work song / audio | sqw200zu | 2 | 1,370 |
03-14-2024, 03:09 AM Last Post: dmitrymyadzelets |
Rock64 won't boot | dstallmo | 0 | 338 |
12-27-2023, 10:34 AM Last Post: dstallmo |
HDMI doesn't work on rock64 | Noung1991 | 1 | 616 |
11-21-2023, 08:33 AM Last Post: as365n4 |
Rock64 + Klipper + KlipperScreen Instructions | godzilla62 | 0 | 612 |
10-22-2023, 01:52 AM Last Post: godzilla62 |
Rock64 Debian 11 (Bullseye) install problem | jbize | 15 | 8,412 |
10-12-2023, 05:14 PM Last Post: tpaul |
arch rock64 does not boot | nemnob | 0 | 592 |
07-09-2023, 03:28 AM Last Post: nemnob |
RXDP from Win10 to Armbian on Rock64 | Transportsicherung | 0 | 652 |
05-27-2023, 06:11 AM Last Post: Transportsicherung |
DietPi OS for ROCK64 | MichaIng | 41 | 33,442 |
12-07-2022, 08:22 PM Last Post: luminosity7 |
Using multiple UART's on Rock64. | ramprasad | 0 | 936 |
08-29-2022, 01:22 PM Last Post: ramprasad |
