rock64 is on Armbian's supported boards list
I downloaded the stretch desktop img and tested yesterday, usb3.0 and gigalan works out of the box.
The link on download page vanishes today, but you can still find it https://dl.armbian.com/
Have fun
Any feedback on performance and stability. Not getting great throughput via USB3 Portable HDD across my LAN (about 40Mbps), not matter NTFS or EXT4. Thanks
(03-16-2018, 11:33 PM)cooker Wrote: I downloaded the stretch desktop img and tested yesterday, usb3.0 and gigalan works out of the box.
Have fun
wow, number 33 on the most frequently downloaded images with a total of 10 downloads. this is a real decent sleeper.
@dkryder
What you expect from a silent candidate at "testing" stage?
I've tried Armbian_5.41_Rock64_Ubuntu_xenial_default_4.4.115 and it's working stable except the fact it's flooding dmesg with the 'eth1 resetting loop' issue (the same as here: https://github.com/ayufan-rock64/linux-build/issues/121). I don't know if it affects the device performance or stability in any way.
The rock64 is there on the main downloads page, you just have to look under the Work in progress section because... well, as far as the Armbian guys are concerned, the image is still a work in progress and still needs a lot of testing before they consider it stable!
https://www.armbian.com/rock64/
Nice to see you online pfeerick. Any particular reason why Armbian decided for Stretch Desktop?
As a side-note, Chromium (and Firefox) work much better in LXDE and MPV isn't really usable for playback right now on the Armbian image.
(03-18-2018, 04:40 AM)Luke Wrote: As a side-note, Chromium (and Firefox) work much better in LXDE and MPV isn't really usable for playback right now on the Armbian image.
Can you provide some inside why LXDE would be (much) better? It doesn't make any sense but anything is possible.
mpv and video playback is another story.
I can offer a guess: more lightweight + different compositing.
Just find that it is on the "real" (instead of working-on-to-be) supported list.
Version is 4.4.124, earlier than the 4.4.126 that I found problem before. I have not tested yet. Hope that is more stable (against kernel compile).
Have Fun.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 158 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 631 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 621 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,491 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,048 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 603 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 657 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,669 12-07-2022, 08:22 PM
Last Post: luminosity7
