Problem Installing Linux on Rock64
Nope, RAM size has nothing to do with it. Do you have an A-to-A cable and UART ?
For starters, if you have an A-to-A cable could you follow the instructions here and later pastebin what rkflashtool n gives you with eMMC mounted on the board?
(01-19-2018, 08:02 AM)Luke Wrote: Nope, RAM size has nothing to do with it. Do you have an A-to-A cable and UART ?
Sorry I dont know what an A to A cable is, nor a UART. So I guess the answer is no.
I just tried flashing and booting with image jessie-minimal-rock64-0.5.15-136-arm64.img.xz
This just gives i/o buffer error mmcblkp1.
A-to-A USB cable
Just tried installing the armbian image:
Armbian_5.34.171121_Rock64_Ubuntu_xenial_default_4.4.77.img
but also same result.
The bios messages about self tests USB connected etc follow ok.
I can plug and unplug mouse and keyboard and the messages on the screen register this ok.
then comes stuff like
mail device driver loaded
ALSA device list
then a list of one lines starting with 'random'
random udevadm uninitialized urandom read
final line is:
random nonblocking pool is initialized
nothing more.
EDIT: Im saying 'bios messages' but maybe they are from the OS image. Some of them reference folders  like /devices and /drivers and BTRFS. The last message line comes about 5 seconds into the boot.
if I was you I would test out the following:
* Try a different power supply, especially if the one you are using is below a 3A rating.
* See if you can get a slower SD card to try. It seems to me that (at least with mainline) the Rock64 may have some trouble with some cards. Like I have some Samsung EVO cards that seem to have problems with the Rock64 but slower Patriot Class 10 ones work OK.
(01-21-2018, 12:05 AM)wilsonYan Wrote: if I was you I would test out the following:
Well I'm using the official power supply adapter which was supplied with the Rock64 so that shouldn't be an issue.
Ive tried three different cards so far. I dont have a slower card than class 10, but the cards I have are all 2-3 years old, one of them brand new.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,425 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,755 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,755 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
