Rock64 and ALSA (Multichannel and HighRes)
Music
Hello, everyone!
Merry Christmas and Happy New Year!
I'm looking for a device for music streaming.
I'd like to output sound via HDMI port to my AVR.
Can anybody confirm, that HighRes and surround sound are output correctly using any of the supported distribution? Ubuntu/Debian, LibreELEC, Volumio?
Maybe someone can post outputs of aplay -l command, or even try to do speaker-test with different samplerates and channel numbers?
Does your AVR shows correct samplerate and channels? Are the channels mapped correctly?
I've tried such streaming using HDMI output of my HP ProBook 4530s with Ubuntu 16.04.
Installed upmpdcli and mpd and everything works as expected. AVR indicates correct sample rates and channel number with any source I throw to it. 44.1/48/88.2/96/176.4/192kHz, 2ch or 6ch.
I also have CubieBoard2 and Tanix TX5 Pro devices.
Both devices can only output 2 or 8ch, which is not perfect. I have to do channel assignments via asound.conf, and as a result sound is always output as 8ch.
RPi 3 cannot output anything higher, than 2ch/48kHz.
Rock64 is my last hope to have small small music network streaming device =)
Thanks for your help!
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,430 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,774 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,473 12-07-2022, 08:22 PM
Last Post: luminosity7
