Rock64 crash - spinlock lockup suspected on CPU (possibly thermal reason)
Hi, I often get an error spinlock lockup suspected on CPU#X where x is cpu core number from 0 to 3, one after another. When that occurs in terminal everything freezes and the only way is to reboot the device using force poweroff. It's popping up only under stress (at least 30-50% of all cores) in Chrome for instance. I'm using a 13x13x10 mm radiator with average quality thermal paste. Temperature is about 50-65 Celsius degrees. I'm using latest Ubuntu Artful build. Is it possible that it's caused by thermal issue? Hardware Issue? Or maybe it's because unstable distro?
Please go easy on me, I'm rather beginner.
After further investigation it looks like a chromium browser issue. No problems with eihter stress test and other browsers
Edit2:
It looks like a problem with kernel or drivers, I don't know. Apparently the issues appears also in case of other softwares.
I'm doing stress test using 3 chromium browsers running twitch.tv on stable 0.5.10 release and 0 issues here. Weird.
it might also be the sd card has a problem spot on the media surface. if not too dificult or costly try reflashing the o/s after doing a scan/test of the card.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,416 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,706 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,452 12-07-2022, 08:22 PM
Last Post: luminosity7
