First Lakka image for Rock64!
(11-16-2017, 09:01 AM)KryPtAlIvIaN Wrote: In the past, I've copied and pasted the config values from your controller config file into the retroarch.cfg and it worked. Have you restarted?
Yea. Ok will copy the values over and try again. Will have time in a couple of hrs,  but will report back after trying.
Both I and YC tried different controllers - autoconfig points to /tmp/joypads where the controllers xinput are present. But only some controllers are recognised while others aren't (I only got Xbox 360 and 8Bitdo controllers to work).
I would tell Ntemis about that.
(11-17-2017, 09:55 AM)KryPtAlIvIaN Wrote: I would tell Ntemis about that.
Ok, will you get in touch with him ? You mentioned you're in their IRC ?
Sure can.
try to set joypad driver in menu to udev. Sounds like its on xinput and that input doesn't have nearly as many config files.
Its in udev by default, I managed to get the controller working by setting joystick driver to HID
edit: still, strange that udev would fail to recognise the controller like this ...
edit: hid only recognises some buttons on the controllers. Very strange.
Hello, just jumped over to inform you guys that Lakka v2.1 final is out with Retroarch v1.6.9.
Let me know if anything comes up Smile
Enjoy!
(11-22-2017, 03:53 PM)Ntemis Wrote: Hello, just jumped over to inform you guys that Lakka v2.1 final is out with Retroarch v1.6.9.
Enjoy!
Glad to see you in the forum :Smile Have a read of the thread please - my only complaint was that many common controllers were not recognised, otherwise great. I will check out the new image tomorrow.
Enjoy!
Controller issues should be gone by now Smile
Enjoy!
Excellent - will check it out first thing after I get back from work.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,370 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 616 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 612 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,409 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,653 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,442 12-07-2022, 08:22 PM
Last Post: luminosity7
