pcsx rearmed on rock64 debian stretch does not go fullscreen
anyone else tried pcsx rearmed on ayfan's debian stretch image?
My experience so far is:
If I compile it on rock64 I get wether neon nor dynacrec support which leads to a working build that is way to slow.
Another approach was to build pcsx reamerd on a raspberry pi 3 and copy over the resulting build. Don't build with neon on raspy, too but at least with the very needed dynarec support. Copied the resulting build over to the rock64: Works and is fast enough thanx to dynarec. (Mulltiarch must be installed, to make it work this way).
One Problem remains:
I only get SDL-Window-Output. No fullscreen. Any ideas?
BTW: Controller works too, tried a Steamcontroller with sc-controller.
Interesting, I was under  the impression that you would need 32bit user-space for pcsx rearmed. rtissera was working on getting a RetroPie build for the R64 rebased on armhf. Sadly, I haven't seen him in weeks. Take a look at what he got working in this thread.
how to run ps1 games on Pine a64+ ?
  How to update/compile Debian 12.5? Wizardknight 3 441 03-29-2024, 05:01 AM
Last Post: gedas07
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 618 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 612 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,416 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,704 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
