emmc upgrade
Hi Guys,
This morning I swapped out the 16 Gb emmc module for a bigger 64Gb one. Opening the case was easy! After rebooting from a know working SD card I simply tried to run
/usr/local/sbin/pine_install_to_emmc.sh xenial-mate I get 'You should boot from SD card' ,which I did....
Any help how to continue would be appreciated. Do I need to partition the drive first? I the emmc drive broken? (I checked it is firmly inserted...)
Erik
(08-24-2017, 02:18 AM)Erik Wrote: Hi Guys,
Erik
1- boot stable version from sd card using pine installer.
2- sudo ./pine64_update_kernel.sh 0.7.19
sudo ./pine64_update_uboot.sh 0.7.19
sudo ./pine64_update_package.sh 0.7.19
3- reboot
4- pine64_install_to_emmc.sh xenial-mate 0.7.19
  eMMC compatible with Pinebook leperotero 0 1,378 07-19-2022, 07:15 AM
Last Post: leperotero
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,637 06-07-2022, 10:35 PM
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 1,518 10-16-2021, 02:03 PM
Last Post: quixote
  How to write image to emmc module on the pinebook eclay 16 33,831 06-11-2020, 03:03 PM
Last Post: jezek
  Replace/Upgrade trackpad tophneal 6 10,678 01-10-2020, 02:30 AM
Last Post: karlitos
  pinebook to pro upgrade path? dhosh 13 18,375 11-14-2019, 11:25 AM
Last Post: bcnaz
  LCD Upgrade Lyga 14 20,486 07-30-2019, 09:59 PM
Last Post: binholz
  EU Shop for spare parts/eMMC? Noxmiles 4 5,688 07-05-2019, 03:16 PM
Last Post: soupbowl
  how to install emmc in just arrived pinebook dkebler 11 24,695 06-13-2019, 01:13 AM
Last Post: zk1sps
  eMMC replacement problems. frank-zappa 3 4,527 01-08-2019, 04:35 AM
Last Post: frank-zappa
