No USB Power after Login (ROCK64+Mate)
#31
(10-11-2017, 01:53 AM)mshock Wrote: Just reseived my ROCK64, installed the Debian LXDE 20170809 to microSD card, booted. USB keyboard and mouse (connectred to USB 2.0) worked before login/password window, but then mouse and keyboard stopped working.  Tried to connect my mouse and keyboard via an active USB hub with the same result!
They work with stock Android image, but not stable.
May the problem be in the insufficient power supply? - I use 2.5A PSU.
if you have not tried a recent build of linux by ayufan, try one of those.
(08-17-2017, 04:52 AM)MarkHaysHarris777 Wrote: Basically,  on the production boards they tied the usb power through regulators;  two GPIO lines must be toggled to set the regulator or the usb power drops.  For some reason the gpio mux lines controlling the regulators are left floating;  not good.
There are two ways to fix it:  1) dts|dtb , or script , to toggle the mux lines turning the regulators ON,  or 2) mod the board so that the regulators are ON all the time !
The regulators are on the schematic on page 19;    We'll do some testing and see if we can get a software fix;  otherwise, we'll put up a board mod procedure.
Blush
HI
   I am having problems with the USB 3.0 port and my external self-powered HD, wireless mouse and keyboard. Frequently, at boot, the Rock64 behaves like it forgets it has a mouse and/or hd. These devices work flawlessly with my PI III so I do not understand what's going on with my Rock64. Do you have any idea on how to fix this? I used the stock linux. Thx
I have the same problem...
Any solution for this?
Regards
(12-17-2017, 06:21 AM)cpocarlos Wrote: I have the same problem...
Regards
Support told me:
After consult internally, it seems that earlier OS build may having issue on controlling the USB power regulator.
Please download PINE64 installer, select"ROCK 64", the select "Community Xenia Mate" OS buildand burn the microSD card. Make sure the microSD card program successfullywithout error, plug into your ROCK64 board and power on.
Here is the PINE64 installer download link: https://github.com/pine64dev/PINE64-Inst...d#download
Things got much better
Regards!
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 621 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 615 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,442 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,812 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 594 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,481 12-07-2022, 08:22 PM
Last Post: luminosity7
