Linux Images (ROCK64)
#61
(01-14-2018, 08:58 AM)Luke Wrote:
(01-14-2018, 04:33 AM)gene83 Wrote: Point about an x install may be moot, I left it running, but when It was time for amanda to back it up, it had crashed, and it is nor responding to an ssh -Y rock64@rock64 query now at 5:30 am local.  So this one isn't quite ready for prime time. I had such high hopes too.
Cheers gene83
Yes, desktop isn't ready for prime time.
Desktop is definitely ready for prime time. I've been using it daily (ayufan 0.5.15 / debian stretch minimal + xfce) for the last two months and it works just fine.
Cheers gene83
OK, glad to hear.
Thats with Xfce? LXDE sure isn't, I'll switch just for grins. But apparently tasksel can't be run over an ssh -Y connection, I get the prompt back without action or error, in about 2 seconds. But I'll try it the next time I walk by its keyboard.
Thanks & cheers, gene83
Dummy questions....
1- Why is there only one Linux distro that support boot from emmc?
2- Are there some technical problems and/or limitations?
3- Is it possible to convert a Linux micro-sd boot to emmc without using the serial console?
(01-18-2018, 10:33 AM)soichiro Wrote: Dummy questions....
You can boot most most of ayufan's images (as well as LibreELEC and Lakka) from eMMC just fine. In fact, I've only heard reports that DietPi doesn't boot from eMMC.
You can use one of the methods specified in the wiki to flash images to eMMC.
Thank you for letting me know Smile
Can someone give any information in what is present and what is removed from the ayufan images? Not a Linux guru. My build will be really simple when my rock64 arrives. An always on NAS and some minimal interaction with a dekstop gui. Looking at getting the latest Xenial minimal image - 0.6.15 to test with and hope to max at the Gb NIC and USB3 port for data copying sometimes. I noticed ayufan as asking for feedback about 0.6.x becoming the stable build. Thanks.
I just this week, tried the latest 6.x.x image by adding his repo, bricked the sd card. Very noisy failed reboot.. So I've got a different version of the newest 5.x.x waiting for me to fire up dd and re-write the card. Sorry I can't be much more help than that. I've a couple days more work truing up a lathe spindle that's made out of pure unobtainium before I get back to the rock64's.
(01-23-2018, 11:37 PM)gene83 Wrote: I just this week, tried the latest 6.x.x image by adding his repo, bricked the sd card. Very noisy failed reboot.. So I've got a different version of the newest 5.x.x waiting for me to fire up dd and re-write the card.  Sorry I can't be much more help than that. I've a couple days more  work truing up a lathe spindle that's made out of pure unobtainium before I get back to the rock64's.
Thanks gene83.  Haven't heard many good experiences with 0.6.xx build, so will try the 0.5 one.
Does anyone else have feedback of the 0.6xx builds?
I tried both of them (0.5.15 and 0.6.13), and my use is similar to yours: use the Rock64 as NAS.
My first concern is the performance in copying to and from Rock64, using a USB 3.0 HDD.
The performance of 0.5.15 is poor, so I'm testing 0.6.13. So far the latest test with kernel 4.15.0 gives me a real write speed of about 40MB/s and a read speed of about 47MB/s.
I don't remember the speed with kernel 4.4.x.
I installed XFCE as desktop environment, although I'm used to managing it remotely with putty. However, if necessary, you can use xrdp to connect remotely with Microsoft Remote Desktop Connection.
About the stability, I have had no problems at the moment, although the NAS is not always on. I use it only for testing purposes.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 188 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,415 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 370 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 674 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 656 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,727 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 193,214 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 627 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,804 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 677 05-27-2023, 06:11 AM
Last Post: Transportsicherung
