Linux Images (ROCK64)
#41
Updated Jessie OpenMediaVault Community Build Image [microSD to eMMC] [0.5.15-136] by ayufan
I've been using a RPI and BPI for a while now and am pleased to see the Rock64 is ARM64 rather than just ARM... Is there a noticeable difference in performance between 32 bit linux / debian apps and 64bit ones? Realise 64bit will use more memory and storage.
Thanks.
i have the pine64 2 GB and the rock64 4 GB. and from my experience i would bet that if the pine64 had 4GB and was running a 64bit kernel and had a 32bit userspace on the pine64 it would outperform the rock64 in some applications like making changes to large text files, running diffs on good sized code blocks and others. but in video applications rock64 wins all events.
Updated Debian Stretch Mate Community Build Image [microSD Boot] [0.5.15-136]
Thumbs Down
(12-21-2017, 12:27 AM)pineadmin Wrote: Updated Debian Stretch Mate Community Build Image [microSD Boot] [0.5.15-136]
This new image also only detects my FullHD monitor with only 800x600 resolution.   Angry   ( Rock64 4gb v.2.0)
sudo apt-get update -y && sudo apt-get upgrade gives me an error:
you might want to run 'apt --fix-broken install'
when i do this libgles1-mesa (>=7.8.1) is not installed and DPKG has error processing libgles1-mesa_13.0.6-1+b2_arm64.deb overwriting libGLESv1_CM.so.1
Updated Debian Stretch Mate Community Build Image [microSD Boot] [0.5.15-136-20171222]
(12-22-2017, 04:24 AM)pineadmin Wrote: Updated Debian Stretch Mate Community Build Image [microSD Boot] [0.5.15-136-20171222]
NO Change log but you fixed the update bug. Wink
one url is not working
You don't have permission to access /os/ROCK64/debian/stretch-mate-rock64-0.5.15-136-20171222-arm64.img.xz on this server.
But I still get 800x600 max resolution Angry
you are doing something wrong because that build on my rock64 runs at default 1920x1080 60Hz with options for 1280x720 and 800x600 as shown by mate control center displays selection.  so i would say there is something wrong with your hardware setup or how you have your software configured. the pastebin you linked is gone so can not comment on that.
No it must be a hdmi thing.
If I plug it with my Samsung tv I get full hd resolution, just not with my pc benq monitor..!
Here I only see hdmi unknown.
Xrand is not helping either and i dont know how to import the edid.
nice to know you finally established the build does work unless there is something wrong with the hardware setup. what model is the benq?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 186 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,414 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 367 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 670 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 653 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,716 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 192,840 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 626 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,799 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 676 05-27-2023, 06:11 AM
Last Post: Transportsicherung
