Does the ROCK64 support CEC over HDMI?
Does the ROCK64 support CEC (Consumer Electronics Control) over HDMI?  CEC allows the SBC to turn a connected HDTV on (and off) over HDMI, change the HDTV's input, and possibly control other functions.
I believe the Raspberry Pi has CEC support.  While I have never used CEC on a Raspberry Pi, I do have some project ideas in mind.
More info here:
http://elinux.org/CEC_(Consumer_Electron..._over_HDMI
Thanks!
Yes. It already does work on Android, but controls to support that on Linux are also present: https://github.com/rockchip-linux/kernel...nable&type=. We may need to upgrade libcec to support a new device, but I wonder if exynos compatibility layer would not work OoB.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(07-05-2017, 02:53 PM)ayufan Wrote: Yes. It already does work on Android, but controls to support that on Linux are also present: https://github.com/rockchip-linux/kernel...nable&type=. We may need to upgrade libcec to support a new device, but I wonder if exynos compatibility layer would not work OoB.
I can find the cec function in the hdmi settings. but unfortunately they turn off automatically after turning on. I used the cec function under LibreElec Leia of Raybuntu but this operating system is absolutely unstable and does not work as required. for my purposes, only the android of ayufan currently works properly. Thanks a lot for this. the more I would be glad if the cec problem and one or the other bugs could be solved. I also regularly experience a loss of network connection via the RJ45 socket. if I unplug the cable and insert again the connection is immediately available again but unfortunately not constant. I use the regular android 7.1.2 root version.
thanks again for your great work and keep it up. I will test your pre-releases today.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,421 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,732 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,459 12-07-2022, 08:22 PM
Last Post: luminosity7
