New Pinebook 14'' does not boot from sd card
#21
(07-27-2017, 06:25 AM)tillea Wrote: However, I now want to flash my 64GB eMMC and I realised that I need another image for this and those dedicated eMMC images do not contain Q4OS.  I admit I keep on wondering why this is so complicated with flashing prepared images instead of simply firing up an installer as I was using on intel based machines.
That shouldnt be a problem Smile
because if you boot Q4OS from SD-Card there should be an installer-icon (like on a PC-live-cd).
That will install Q4OS to your 64GB eMMC.
The only negative on this install-routine is that the installer once more do download the Q4OS Image (which you already flash/dd/win32diskimager or USB-IT to your SD-Card) - but it works fine on my Pinebook (Q4OS v1806 for the Pinebook)
Sounds easy for me ;-)
You neeed the adimq-password and you have to be connected to the internet...
#22
(07-25-2017, 03:42 AM)guidol Wrote: Q4OS is build on debian 8 Jessie.....isnt that enough?
İf you disable the DE and do edit sources.list - isnt that debian not near enough a "real" debian-system? ;-)
After now having successfully put that on SD card I can confirm that this is enough for my purpose (provided an upgrade would work flawlessly as I know it from any intel based maching).  However, I now want to flash my 64GB eMMC and I realised that I need another image for this and those dedicated eMMC images do not contain Q4OS.  I admit I keep on wondering why this is so complicated with flashing prepared images instead of simply firing up an installer as I was using on intel based machines.  I've got the advise that I should wait a bit until there might be Debian based eMMC flash images, but I had expected that I would get this machine up and running a bit faster.
Thanks for all the hints anyway, Andreas.
Ah nice... i didn't realise Q4OS was based on Debian (or should I say that now that I write that, I do remember that it *wasn't* based on Ubuntu Xenial Wink Learn (and re-learn) something everything every day!
(07-27-2017, 09:01 AM)Luke Wrote:
Quote:I admit I keep on wondering why this is so complicated with flashing prepared images instead of simply firing up an installer as I was using on intel based machines.
I'll quote Xalius here:
Quote:Just because RPI made embedded Linux seem simple doesn't mean that it actually is.
(not an actual quote)
I'll also add to that:
"Just because ayufan makes developing linux images for the pine64/rock64 seem simple doesn't mean it actually is." :-P
And also as this extra info as well Wink It is complicated for a number of reasons, but the big one (apart from closed systems and lack of documentation) is because the x86 platform is relatively simple in comparison to ARM, and has been around a lot longer. With x86, the instruction set is (relatively) the same, and the BIOS (and now EFI) did all the heavy lifting of getting the system started. No such luck with ARM... you have to do everything yourself, and each ARM manufacturer does things slightly differently, so it really is re-inventing the wheel each time. Can't just take a pine64 image and slap it on a rock64... AllWinner A64s do not work the same as Rockchip RK3328s. Same as you can't boot a OrangePi from a Raspberry Pi image, etc, etc, etc. Once you get a lot of the basics down... boot stuff, kernel, yeah, sure, you can slap in a generic rootfs... but even then, you need a aarch/arm64 one for 64bit ARM CPUs, and an armhf for the 32bit ones... etc... etc... Basically... it's not simple! :-P Now, if manufacturers started adding SPI flash and make a EFI loader ("BIOS") for their board before releasing it... that would make life SO much easier.... that is slowly starting to happen.
  pinebook 1080p power/barrel connector/cable cel 0 545 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,378 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,230 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,637 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,336 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,614 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 2,999 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,622 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,811 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,679 08-20-2020, 08:18 AM
Last Post: Reinoud
