New Pinebook 14'' does not boot from sd card
I recently received the pinebook.
One of the first things I did was to flash an android image to a sd card (8 GB) using the PINE64 Installer.
Did not boot from the sd card. With any other os I flashed - pinebook did not boot from sd card.
Tried to turn into FEL mode (long press and then at least 3 short taps), did not work.
All in all, pinebook booted the eMMC image unless I did.
The sd card slot is working: If booted with the eMMC image OS I can read any sd card I plug into.
So I removed the eMMC and tried to boot from sd card, failed also. But switched into FEL mode.
I currently haven't build a serial console (via audio) connector cable (missing parts) to see what's happening while trying to boot from sd card.
My questions:
- Does anybody struggled into the same behaviour? Or what's wrong with sd cards the pine installer flashes?
- What are the FEL key's? Or how do I force the pinebook without removing the eMMC into FEL mode?
Did you select "Pinebook" in the dropdown during image selection in the installer?
https://forum.pine64.org/showthread.php?tid=4661
(07-02-2017, 10:40 AM)felfail Wrote: I recently received the pinebook.
My questions:
I have the same problem.
I have to admit I did start having issues with some of the SanDisk microSDs (the class 10 red and grey ones) that I would usually use for short term testing. I've switched over the Samsung EVO cards and have had no issues as yet, and a serious performance boost. My advise is to get yourself one, verify it to make sure it's not a fake or faulty, and then try again.
Also, can you be more specific... if you only get a blank screen, then it's either a faulty card, or a bad/wrong image. If you get the boot logo, it's probably a faulty card... I would often get the boot logo, but the system would just lock up, and my serial console would be reporting card errors (although the cards would pass verification, so it seems the pinebook just didn't like them).
(07-04-2017, 04:28 AM)pfeerick Wrote: I have to admit I did start having issues with some of the SanDisk microSDs (the class 10 red and grey ones) that I would usually use for short term testing. I've switched over the Samsung EVO cards and have had no issues as yet, and a serious performance boost. My advise is to get yourself one, verify it to make sure it's not a fake or faulty, and then try again.
Can you please benvhmark that samsung evo card using hdparm -t?
My questions:
My problem has solved. My 128gb Samsung sdxc replaced to an Sandisc 16gb sdhc and it works well.
(07-04-2017, 06:36 AM)Wizzard Wrote: Can you please benvhmark that samsung evo card using hdparm -t?
Samsung EVO 32GB, with no changes to performance governor, etc, on 11" pinebook, Linux pinebook 3.10.105-bsp-1.2-ayufan-65 #1 SMP PREEMPT Mon Jun 5 06:57:47 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
sudo hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads:  62 MB in  3.03 seconds =  20.45 MB/sec
sudo iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
    Run began: Wed Jul  5 03:34:10 2017
    Include fsync in write timing
    O_DIRECT feature enabled
    Auto Mode
    File size set to 102400 kB
    Record Size 4 kB
    Record Size 16 kB
    Record Size 512 kB
    Record Size 1024 kB
    Record Size 16384 kB
    Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
    Output is in kBytes/sec
    Time Resolution = 0.000001 seconds.
    Processor cache size set to 1024 kBytes.
    Processor cache line size set to 32 bytes.
    File stride size set to 17 * record size.
                                                             random    random     bkwd    record    stride
             kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
         102400       4     1119     1820     5943     5938     5940     1825
         102400      16     8114     5833    13488    13518    13494     5277
         102400     512    16983    17567    22884    22952    22932    17597
         102400    1024    16687    16138    22813    22908    22909    17406
         102400   16384    17214    17546    22695    22765    22806    17541
(07-04-2017, 02:59 PM)tozsoferguson Wrote: My problem has solved. My 128gb Samsung sdxc replaced to an Sandisc 16gb sdhc and it works well.
Glad you got it working! Wink
Very good hint, thanks! As I now could access the console (via switched "audio" plug), I saw, that my microSD card wasn't recognized during boot0. And - it is a ScanDisc class 10 grey one. So I'll get another microSD (Samsung EVO) and keep you all informed.
@xalius according "Did you select "Pinebook" in the dropdown during image selection in the installer?" -> yes I did. And also plugged in power ...
My questions:
32GB SDHC are working, SDXC not.
So Samsung 32GB EVO SDCD works, ScanDisk 64GB SHXC not, ScanDisk 32GB SHDC works ...
Seems, that SDHC cards are working, SDXC not.
Confused Huh
Hm... that's interesting... I was getting hit and miss results with the Sandisk 8 and 16G SDHC cards I was using... and as you suggest, no luck at all with the 64GB SDXC Sandisk card... so moved to the Samsung Evos (16 & 32GB) and haven't had any issues at all since. Maybe I should get a Samsung EVO 64gb to test that, as that will bump it over toe SDXC again...
  pinebook 1080p power/barrel connector/cable cel 0 535 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,363 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,213 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,615 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,293 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,591 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 2,970 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,589 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,725 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,667 08-20-2020, 08:18 AM
Last Post: Reinoud
