USB cable to power device
What is the USB cable that I need to power the Pine64?  Is it a USB mini?  Ron
(02-26-2016, 01:03 PM)Ron Piggott Wrote: What is the USB cable that I need to power the Pine64?  Is it a USB mini?  Ron
Micro USB, connected to a 5 volt 2 amp power source.
If you take a look at the wiki.pine64.org page you'll find info about this.
But to make things a bit easier, here is the image I'm refering to
[Image: Pine64_Board_Connector.png]
As you can see the power connector is a microUSB.
Is this correct then:
Ultra 30cm 1FT USB 2.0 A Male to Micro 5pin Male Plug Data Leads Cable
(02-26-2016, 02:03 PM)Ron Piggott Wrote: Is this correct then:
yes thats the cable you need, but you allso need a wall-plug that supply at least 2A.
That cable is fine.
Other options are
1. http://www.ebay.ca/itm/3-3ft-Black-Micro...1291557319
2. http://www.ebay.ca/itm/Black-Micro-USB-D...1384834523
Note that you also need a USB charger, preferably at 2A.
See, for example, http://www.ebay.ca/itm/5V-2A-Travel-Wall...1954131663
Would you look at this one for me, there are restrictions on the first one I found that I can't buy several for my coming Pine cluster.
80cm USB 2.0 A Male to Micro 5 Pin Male Plug Adapter Short Power Data Cable Cord
(I know I have to have power for each board)
(02-26-2016, 03:49 PM)Ron Piggott Wrote: Would you look at this one for me, there are restrictions on the first one I found that I can't buy several for my coming Pine cluster.
Personally I prefer using AliExpress for this type of purchases. I found a 100cm usb cable for you there at US $0.40/psc (you can order 17 without any shipping fees beeing added, but if you choose 18 there is a $6.5++ fee depending on how many cables you order), but I asume you wont be needing that many cables...
The item can be found here... (be aware of the (most likely) slow shipping. Most items from AliExpress is taking forever to arrive... At least to Norway where I live).
Any microUSB cable should be fine, including that one.
Since you are planning to use on a cluster, you may select a long cable that is flexible.
When do you expect to receive your Pine64s? If it is more than one month, you can buy
from Aliexpress. Select a seller that has good reputation and there is lots of positive feedback.
Aliexpress is good because sellers are fighting to build reputation.
If a cable has a defect, you can ask for a new one to be sent.
Am I missing something? Are micro usb cables super-rare in Canada?
Having said that, I'm a fan of Aliexpress too. As long as you choose reputable sellers by studying their feedback (as taros mentions), you can't beat shopping for stuff there in terms of price.
But a micro usb you can pick up pretty much anywhere for cheap. Yes, you can pay more for some, you can get cables with extra shielding, or braided or flat or whatever - that's gonna cost you more...but largely speaking, there shouldn't be any trouble walking into your local discount store and picking up a cheap micro usb cable.
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,536 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 38,939 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,617 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 15,703 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 29,485 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 11,183 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 53,215 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,856 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 29,693 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 58,160 10-05-2016, 06:43 AM
Last Post: Ghost
