First cable for Euler Bus power done!
My little project for tonight (I forget how shaky my hands are until I start soldering..)
[Image: 2a4xnxy.jpg]
[Image: 28hzrqp.jpg]
I'm using a USB-A 2.0 connector on the one end (for my Anker power brick) and a .1" pitch 3 pin receptacle on the other end, with 20 gauge wire in between.
I threw some braided cabling and heat shrink on to cover up my sins Smile
If there is any interest in a more detailed write-up and part numbers etc. just post here and I should be able to get it up sometime this weekend~
AVL
~very nice... just make sure that your 'sins' are NOT cold solder joints or possible 'short' points ! Covering them with electrical tape or shrink tubing looks good but can hide problems later when you can't figure out that mysterious powering problem. ;-)
I assume you're plugging that into euler pins (4) (6) (8) ?
No in this case my sins are of the "I didn't braid the cable as prettily as I could have" variety Wink . I saved the cold joints for my prototype cable (not soldering in a year, I figured a little practice was good, so I bought extra parts).
I actually went with (2) (4) (6) based on this picture :
http://linux-sunxi.org/File:Pine64_Power...nector.jpg
Can you please post the plugs you used?
I made one myself with a PST connector for the Euler bus but I think the connector you used is more neat.
Also, is this a 3mm sleeve?
Hi g_t_j!
The connectors are : http://www.digikey.com/product-detail/en...ND/5246541
I would not use these connectors in a free-hanging application or without some sort of heat shrink stabilizing them, for free hanging applications I'd pick something from these options :
http://www.digikey.com/product-search/en...ageSize=25
For the USB-A end I used : http://www.digikey.com/product-detail/en...ND/1007894
The Braiding is 1/4" : http://www.digikey.com/product-search/en...30-1055-ND
The heat shrink I used is : http://www.digikey.com/product-search/en...53x038b-nd
I hope this helps! Smile
AVL
Thank you very much! Great job
I'm going to try modifying some USB A to USB 4-Pin headers by moving the GND pin to connect with pin 6.
7/27: The cables arrived, then I realized that I need a way to change the gender (duh). Since I already have short USB A male to USB micro male that I like, I opted to get USB A male to USB micro female to connect the two cables together. It is difficult to find short USB A male to USB A male cables and they aren't cheap. This is definitely more expensive than making your own cables, but does save time.
8/1: I swapped the GND and USB Data+ and plugged into Euler and it worked perfectly, so all 5 boards I have are now powered via Euler with no problems.
Backer #17,640
Hello, I am very interested in feeding my pine64, you could put as working with the cable and the USB connector?.
thanks and greetings.
What does this do?
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,522 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 38,832 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,609 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 15,680 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 29,436 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 11,173 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 53,137 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,830 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 29,651 01-07-2017, 11:59 PM
Last Post: aegrotatio
  Correct Voltage For Powering From Euler?? thisrestricted 7 18,194 10-18-2016, 06:49 PM
Last Post: veronicasmithen03
