Once Again: Power Supply problems I guess (Pine A64+ locking up)
I'm using a Pine A64+ 2GB on the openHAB distro but the problem is every 3-14 days my PineA64+ locks up completely. It's powered from the micro usb with a very good power supply 3.0 Amps with nominal jitter or noise.
The only other thing connected is a SSD where the main file system is located through USB Port.
My guess is that it's still the power supply, but do you think it would help cutting of the Micro USB to power it through Euler? Problem there is also I don't know where to get the connectors to plug onto the wires to connect them with euler bus.
Or do you think it could be something completely different, can it still be too much noise? Are there readymade filters one can buy somewhere? I read about a filter here in the forums but I don't have those parts at hand easily and would prefer buying something more soild.
Or do you think the culprit maybe the USB port for the file system?
Thanks for any help because currently I have to use a external watchdog which resets the board if this happens which is not really a desired behaviour.
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,246 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 37,834 12-19-2020, 09:53 PM
Last Post: evilpete
  Power supply problems. larsen8989 5 15,217 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 28,476 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 10,788 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 51,611 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,478 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 28,874 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 56,205 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 10,872 10-02-2016, 04:35 AM
Last Post: pfeerick
