Found this fully working RASPBIAN Image that boots to desktop
This link to this image has been tested by me, I can verify HDMI Ethernet, Wifi, and USB after configuring the text file on windows then rebooted to a fully supported A64 Raspbian Image
 https://drive.google.com/file/d/0B_YnvHg...BFSnM/view
this works unexpectedly well.
I just saw you joined the chat (at 4.00am hence no answer). The image you are linking is dated 2016-07-13 so whatever it is, its not new. Also, Raspbian ?
I'm a little confused about what this img is ....
[edit] so upon a closer inspection, it seems is to be a banana pi m64 image. Where did you get this thing?
[edit 2] So yea, it boots. And yea, uses RPI repos and runs 3.10.101 kernel. I will set up a VNC server and take a look at it next.
[edit 3] It boots into the (old) RPI desktop. It also has raspi-config (most settings don't work) and other utilities.
[edit 4] update scripts are in /usr/local/bin --- haven't tried updating.
If anything, this is an interesting finding ...
http://www.banana-pi.org/m64-download.html
yeah, I just read about the banana pi 64, it uses same A64, Mali Drivers, but uses onboard flash, so I just wrote the image to a sd card, put in and booted up, I waited to see any ethernet activity, and when that happened, I shut down, and pulled the sd card out to read the decompressed files, and edited the command line text for HDMI, and boom, booted to the desktop with all my USB working, ethernet, HDMI.
I am a newb with this, but I pick up fast so I half way have an idea of what's going on, it wasn't a blind try when I decided to boot it.
https://drive.google.com/file/d/0B_YnvHg...sp=sharing
oh yeah here is a link to the image in my google drive for whom ever wants it.
works here. this bpi-m64 board is not yet for sale however they claim 1080p/ 4k video on the same mali400 mp2 GPU. it has 8GB/16GB/32GB/64GB eMMC flash & sd card slot. pine64 could hopefully pick up a few tips for the next pine64 dev board. the o/s makes several outright references to pine64 so it seems they have taken a bit of pine64 & longsleep kernel work. i wonder why it has seemingly slowed to a crawl since july, that's about 4 months without bringing a board to market yet.
yeah they use longsleeps work for this for sure. I was amazed it worked so well, there are multiple various builds for the pi64, that Im sure are all based on the pine64 work.
Thanks. i was looking for a simple image to run magic mirror
downloaded this image and it boots to the desktop. and i was able to login via PUTTY with the username/password from their forum
What are my next steps ? Should i follow the guidelines in the rpi forum to expand the SSD / change password / install magic mirror or is there some other work that's needed ?
Never used Linux in my life, but i can follow directions
Have a Pine 64/2GB board
thanks
Thanks a lot for the image,
what are the credentials to login ?
(12-24-2016, 08:49 AM)Shai Wrote: Thanks a lot for the image,
its
pi/bananapi  &  root/bananapi
amm.. the network/bluetooth card isnt recognized..
who can help on that?
(12-15-2016, 10:13 PM)speedro86 Wrote: This link to this image has been tested by me, I can verify HDMI Ethernet, Wifi, and USB after configuring the text file on windows then rebooted to a fully supported A64 Raspbian Image
can you please explain what does it mean to edit a text file to make it work?
  Gentoo Linux test image xalius 23 68,607 01-28-2019, 11:05 PM
Last Post: necrose99
  eta linux image?? firosiro 1 6,339 08-03-2017, 10:05 PM
Last Post: pfeerick
  Possible to get 4K resolution on Linux desktop? tycoonbob 6 16,734 01-12-2017, 01:28 AM
Last Post: swinging
  Pine64 as a viable desktop replacement ? here are my thoughts! Luke 11 25,869 01-06-2017, 04:49 AM
Last Post: dkryder
Big Grin Docker image based on gentoo crossdev arm64 and distcc uulaoba 0 4,413 11-19-2016, 09:34 AM
Last Post: uulaoba
  Ready-to-use image with no graphic interface and SSH on babolivier 9 17,677 10-08-2016, 06:19 PM
Last Post: pfeerick
  Remote Desktop Support? Rochambeaux 20 44,119 10-01-2016, 05:08 PM
Last Post: HayseedGeek
  How to make multicast working on ubuntu and debian brengthdom 3 10,206 09-18-2016, 02:05 PM
Last Post: brengthdom
  Creating a complete linux image yuvgin 2 7,740 09-14-2016, 10:00 AM
Last Post: tkaiser
  How to boot alternative kernel image with u-boot? zhouer 3 10,068 06-27-2016, 04:15 AM
Last Post: ssvb
