How to make multicast working on ubuntu and debian
Hi, I run VLC on Linux OS (Ubuntu and Debian) but it seems VLC cannot receive multicast stream. I can see that IGMP_JOIN is not sent out when trying to receive from multicast IP address (IPv4). I also tried a test program as calling setsockopt IP_ADD_MEMBERSHIP which should send out IGMP_JOIN, but it is not sent. After some investigation, I can see that CONFIG_IP_MULTICAST is listed as disabled in /proc/config.gz. Maybe this is the reason, but I am not sure. How to make it working? Did anyone send IGMP_JOIN successfully? Thanks a lot.
Any thoughts? ...
You definitively need to have CONFIG_IP_MULTICAST=y and recompile the kernel.
(or you can use Armbian Beta image provided here http://www.armbian.com/pine64/)
Thank you very much. After compiling the kernel with CONFIG_IP_MULTICAST=y, VLC can send IGMP JOIN now.
  Arch, Debian or other for Pinebook? cootcraig 3 11,628 05-01-2019, 09:11 AM
Last Post: cootcraig
  Issues with both Deb and Ubuntu germanshep 0 4,441 08-28-2018, 05:47 PM
Last Post: germanshep
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 17,075 11-02-2017, 06:34 AM
Last Post: XaRz
  Found this fully working RASPBIAN Image that boots to desktop speedro86 21 45,113 10-07-2017, 10:06 PM
Last Post: speedro86
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 13,136 03-01-2017, 02:46 PM
Last Post: dkryder
  Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) Quintus23M 9 26,041 02-03-2017, 05:50 AM
Last Post: pfeerick
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 7,642 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 10,700 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 5,911 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
  Overclocking ubuntu mate Mixermic 2 8,047 10-01-2016, 04:36 AM
Last Post: pfeerick
