Pine64+Ubuntu+Tvheadend+DVBT Dongle
Hello
I am trying to run Tvheadend over Ubuntu 16.04 LTS (GNU/Linux 3.10.102-3-pine64-longsleep aarch64)
with dongle Bus 001 Device 002: ID 0572:c688 Conexant Systems (Rockwell), Inc. Geniatech T230 DVB-T2 TV Stick
I couldn't make the compile of tvheadend so i have used a prepared .deb file and the service is working just fine. the thing is that the DVB dongle is not recognised on the Tvheadend.
some1 can help?
Getting the dongle to work is a task for the kernel.
It should load the needed modules and firmwares. Could you send the output of "lsusb - vvv" "lsmod" and "dmesg" pls?
Found your hardware in another thread
Looks like your stick isn't supported in the *old* kernel we're currently stuck with on the pine. But you should be able to build support for it yourself... Problem is you'll have to rebuild with every kernel update.
https://www.linuxtv.org/wiki/index.php/Geniatech_T230
(10-01-2016, 11:19 AM)waldo Wrote: Found your hardware in another thread
thanks waldo for replying. i feel like a bad deal with the Pine.. i just wanted to upgrade the RPi to better product but I find it very problematic for me, can't run Kodi on Linux and etc..
  Programming languages support under PINE64 baryluk 6 20,763 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,706 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,363 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,695 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,162 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,534 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Issues with both Deb and Ubuntu germanshep 0 4,473 08-28-2018, 05:47 PM
Last Post: germanshep
  Official build procedure of ayufan pine64 r.tanaka 0 4,993 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,660 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,701 12-09-2017, 08:14 AM
Last Post: incoherent
